Multiply float big numbers
Hello
I am new to using Arduino. How can I multiply two big numbers as float? for example,
float A= 2500.0;
float B= 40000000.0;
float G =0.0;
G=A*B
The result was ovf
thank you
Hello! maybe it's better to define the variables you are trying to multiply as double, or maybe even long double.
it should solve the overflow as the numbers you are trying to multiply aren't particularly big.
in second thought a float absolutely should cope with these numbers, so the error is somewhere else.
I don't know if this is the actual code you ran, but it's missing a ';' in the fourth line.
post the complete program (using code tags </>)?
It depends on Arduino used... for Arduino Uno/Nano/Mega a double is synonym of float
thank you for help this is the code
float  A=    2500.0;
float  B=  400000000000.0;
float  G =0.0;
  G = A*B;
Serial.print("    ");
  Serial.println(G);
Thank you, I use nano arduino
What is a purpose of using this big numbers in your program? Can you decrease it range by changing it units? For example replacing 1000000 mm by 1 km?
this is just an example, I need it the same procedure in my actual code
Please return and edit your code, adding the code tags <\> to it. Respect the forum rules!
What for?
ok sure I am sorry
What is the output?
Show the error
ovf
It seems like you skiped the reading forum guidelines.
Read the forum guidelines to see how to properly post code and some good information on how to ask the question.
Please do not post again until you read it completely.
AAAAAAA! What a stupid idea to cap the output instead of switching to scientific notation
  if (number > 4294967040.0) return print ("ovf");  // constant determined empirically
Facepalm :man_facepalming:
“empirically” - AAAAAAA!
It was a fix :slight_smile:
Before the library start outputs "ovf", it printed just "0.00" :slight_smile: so "ovf" is definitely better
A fix? It is not a fix but patch to a handicapped implementation of printFloat
Hey, folks, perhaps you could explain to @ilafi what they've tripped over, and what the fuss is about?
