Pro Micro, big batteries, LEDs with WS2811, LASERS, Guitar
Help please, Circuit Diagram Attached
I'm a bit more in carpentry than electronics, a little experience in coding.
Arduino Pro Micro 5V 16MHz
Project=electric guitar with light up fretboard and laser pointers under the headstock. Triggered by audio input from guitar. Color by pitch on the fretboard, haven't decided how to trigger lasers.
Because it's a guitar, I don't want to have to do battery changes on stage, so I got 3 LiPo 3.7V at between 2500 and 3000mAh each in series to power everything.
I don't want to fry my arduino.
I've highlited my question mark areas in blue, but if someone sees something else, that would be greatly appreciated.
Question 1:
Do i need a resistor between my cell array and the arduino if I'm running into the RAW pin on the pro micro. I know current limiting is good, but if the arduino is realistically not powering much of anything (1 PWM, 4 digital pins) will it pull enough that I would need a resistor so that it does not fry?
Question 2: Same deal with my lasers. 2 are extracted from a laser pointer with their own limiting circuit. 2 are going to be bare diodes with a current limiting resistor (my diagram doesn't show it, but there are 4 laser circuits in parallel, each with their own arduino pin), i've hilighted a resistor before the voltage regulator in the circuit. Do i need to limit current? That resistor will eat up a lot of my power if it is in there, or will this likely be fine without, as the circuit should only pull what it needs for current right?
Question 3: The LEDs on the WS2811 chip seem to be acting up. I'm pretty sure the code works fine, because I got it from another friend's project which does not have the same error. It seems like their default or error state is white.
They will function properly for 2 or 3 seconds (irregular intervals, leading me to think it's a glitch, not a coding problem), then sporatically flash in seizure mode (for about 1 second) and sit on white for random intervals(between 1 and 30/40 seconds, then randomly work again for a few seconds). While testing, the arduino and the leds are being supplied by different power supplies (USB and the cell array respectively). Someone told me I'm putting excess electrons into the circuit by not having them share a ground. Could that be causing the error, or is it something hardware related. Once this thing is together, there will be no change in hell of servicing it, because the chips are to be glued between two pieces of wood, as the LEDs are embedded in the fretboard of the guitar.
Please Help!
Question 1:
ANSWER: NO, that makes no sense. Why ? Because the 3S Lipo (2500mAh) is also probably at least 25C , meaning the allowable
DISCHARGE rate can be 25 times the CHARGE rate (which is 1 C) In other words, this battery pack can probably deliver at least
30 to 40 A for a 10 seconds burst and the contiuous current rating would be about 20A. Therefore , the battery doesn't have a problem with a lot of current. The battery's weak link is that it CANNOT be used below the voltage of 2.3V per cell (3*2.3= 6.9V)
This means that if the fully charge voltage is 8.4V for a 3S, then when the voltage gets to 7.1V, the arduino should turn on some indicator light flashing rapidly on the back of the guitar where the audience can't see it.. Just use a 3S,2P battery (3 in series x 2 in parallel )
What you need is to sense the battery voltage using a voltage divider so you can detect it when it gets low BEFORE it is so low that the arduino Vcc drops BELOW 5V affecting the accuracy of the analog input.
You need to show a complete schematic of what you are proposing because your comments indicate that you are just making stuff up as you go along without actually having a sound basis (such as Ohm's Law) for doing so. I'm not trying to make you feel bad but the questions you are asking suggest that you need to consult someone before proposing a schematic.
ANSWER:
I'm not going to answer the question as stated. Post a complete schematic (WITHOUT) any additional components such as you are suggesting. Just show the laser diodes and post the datasheets or list the specs. If you have links to the vendors that would help.
What do you mean by "Step-down Mosfet" . I'm afraid that isn't going to cut it for a specification. You need to cite a specific part number and type of device. It sounds like you are implying a regulator circuit using a mosfet. Instead of re-inventing the wheel it makes for sense to specify a 3A 5V regulator power supply. The whole current limiting line of questioning should just be avoided for the moment until we see the complete proposed schematic and some specs.
Question 3: The LEDs on the WS2811 chip seem to be acting up. I'm pretty sure the code works fine, because I got it from another friend's project which does not have the same error. It seems like their default or error state is white. They will function properly for 2 or 3 seconds (irregular intervals, leading me to think it's a glitch, not a coding problem), then sporatically flash in seizure mode (for about 1 second) and sit on white for random intervals(between 1 and 30/40 seconds, then randomly work again for a few seconds). While testing, the arduino and the leds are being supplied by different power supplies (USB and the cell array respectively). Someone told me I'm putting excess electrons into the circuit by not having them share a ground. Could that be causing the error, or is it something hardware related. Once this thing is together, there will be no change in hell of servicing it, because the chips are to be glued between two pieces of wood, as the LEDs are embedded in the fretboard of the guitar.
ANSWER:
You have to find some other source of power besides the USB. It's ok to have the USB connected if you have an adequate 9V (approx) dc external power source plugged into the dc power barrel jack. The RGB testing will require this. When the "cell array" (which, BTW, the correct name for this a "3S /2500mAh LIPO " (3S stands for 3 in Series) is powering the arduino external dc barrel jack, the USB +5V is blocked because the mosfet switch on the arduino senses the voltage at the barrel jack is > 3.3V and turns off the mosfet that normally allows the USB power to the board, so NONE of the power is coming from the USB.
someone told me I'm putting excess electrons into the circuit by not having them share a ground. Could that be causing the error, or is it something hardware related
I'm not going to comment on that description about excess electrons but suffice it to say, the RGB's power source ground and
the arduino ground SHOULD BE CONNECTED TOGETHER AT ALL TIMES. Let me rephrase that , EVERYTHING CONTROLLED BY THE ARDUINO MUST HAVE A COMMON GROUND WITH THE ARDUINO GROUND. (not yelling, just emphasizing , ok)
FYI, your battery symbol is backwards . (see attached photo)
You need to post a revised complete schematic. According to your schematic, everything is already sharing a common ground so I am a little bit confused by your question about the extra electrons remark from someone. It sounds like they were trying to describe a "Ground loop" but if you didn't have a common ground it wouldn't work. Your schematic is correct as far as the grounds are concerned.
1 - base resistor for 2n2222 transistor seems a bit small. How did you calculate the value for that resistor ? (or did you just pull a number out of the air ?)
2- I can't find a datasheet for the LMS1117 3.3v regulator but you don't put there is no reason for the 1 ohm 2 W current limiting resistors in series the LMS1117 3.3V regulator input. It doesn't help anything because the regulator will just shutdown automatically if it is overloaded. Your going to have to post the datasheet for the laser diode because your infomation is conflicting with your comments. You show the laser diode as a "200mA " device and then you claim it only draws 10 mA. That doesn't make sense.
Your schematic serves the purpose but confirms what you already stated about your limited electronics experience . (the way the transistors are shown, battey symbol backwards) which suggests that you made the right choice in posting and should refrain from designing any circuits without consulting someone on the forum.
Thank you very much raschemmel!
raschemmel:
The cells I have have their own low voltage shut off and charging circuits built in, I wouldn't be worried too much about when it is about to die for right now, but I will definitely keep that in mind as it's a great idea!
Schematic is included. I have included a new proposed schematic based on your input and using a transistor resistor calculator.
I have also attached a schematic of where I was at when I was having problems. That's what I meant with the excess electrons, as before they did not share a common ground or power supply. When I fixed this, I fixed my problem.
Red Laser: Laser Diode - 5mW 650nm Red : ID 1054 : Adafruit Industries, Unique & fun DIY electronics and kits
Green Laser: Laser Module - Green - COM-09906 - SparkFun Electronics
The purple laser is extracted from a 5mW laser pointer I got on eBay, no luck finding a data sheet. their description said "working voltage 2.3-3.7V, <250 mA. At 3.0V it draws approx 47mA. That does include it's own driver circuit
In terms of the MOSFET, it was a kit purchased based on the MP2307DN, with added capacitors and a potentiometer to add variablility.
Hi, the circuit to switch the lasers ON is not correct, the laser should be in the collector circuit not the emitter, see attached diagram.
Sorry 5V should be 3.3V.
Tom...... :slight_smile:
Yes, I agree (I can't believe I didn't catch that).
TomGeorge:
Thanks Tom, rascemmel! My engineering friend explained transistors like valves, I figured it would have to be before haha. Now I know better! Thank you very much!
How do you feel about the rest?
Ps. I know my transistor diagrams are backwards. It's the just way that they ended up seated in my diagram and I wanted to make sure they were oriented correctly with current flow
The way "it is done" is you pivot the transistor symbol as if it were mounted on pivots at the collector & emitter. So when you pivot it that way 180 degrees, the base winds up on the side you want it so you can connect your line directly to the base inside the circle
(FYI, the EMITTER line should go into the circle to connect directly to the emitter instead of stopping at the circle) that's a dead giveaway of a electronics inexperience (a red flag for us, ie: what else is wrong ? LOL)
Does the rest of this look alright now?
