Pro Micro Joystick errors
Hello All,
I am working on a F16 Joystick and am getting non stop errors that I can not figure out.
#include <Keypad.h>
#include <Joystick.h>
#define NUMBUTTONS 19
#define NUMROWS 4
#define NUMCOLS 5
#define joyX A0
#define joyY A1
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3,4},
  {5,6,7,8,9},
  {10,11,12,13,14,},
  {15,16,17,18,19},
byte rowPins[NUMROWS] = {10,14,15,16};
byte colPins[NUMCOLS] = {5,6,7,8,9};
int xAxis_ = 0;
int yAxis_ = 0;
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(0x12, JOYSTICK_TYPE_JOYSTICK, 20, 0,true,true,false,false,false,false,false,false,false,false,false);
  Joystick.begin();
  xAxis_ = analogRead(joyX);
  xAxis_ = map(xAxis_,0,1023,0,255);
  Joystick.setXAxis(xAxis_);
  yAxis_ = analogRead(joyY);
  yAxis_ = map(yAxis_,0,1023,0,255);
  Joystick.setYAxis(yAxis_);
  CheckAllButtons();
delay(0);
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
I am getting the following errors
Arduino: 1.8.19 (Windows 10), Board: "Arduino Leonardo"
code:28:1: error: 'Joystick_' does not name a type; did you mean 'Joystick'?
 Joystick
D:\3DPrints\F16Joystick\code\code.ino: In function 'void setup()':
code:32:11: error: expected unqualified-id before '.' token
   Joystick.begin();
D:\3DPrints\F16Joystick\code\code.ino: In function 'void loop()':
code:40:11: error: expected unqualified-id before '.' token
code:44:11: error: expected unqualified-id before '.' token
D:\3DPrints\F16Joystick\code\code.ino: In function 'void CheckAllButtons()':
code:61:39: error: expected unqualified-id before '.' token
code:65:39: error: expected unqualified-id before '.' token
exit status 1
option enabled in File -> Preferences.
Tried that and now I get Code:28:25 erroe Joystick_Type_Joystick was not declared in this scope.
You need this joystick library:
