Hello,
I have Pro Micro
(picture http://www.jayconsystems.com/media/catalog/product/cache/1/image/800x600/040ec09b1e35df139433887a97daa66f/j/a/jaycon_systems_promicro_1.jpg)
(other picture http://www.uctronics.com/static/images/20130828/arduino-pro-micro-atmega32u4-16mhz-00b89c8d-800x800.jpg)
When I use arduino IDE I can program the device without any problems. However, when I try to use avrdude from terminal, I get 'programmer is not responding' error.
Here is verbose output with Arduino IDE:
[size=10pt]/home/XXX/arduino-1.5.6-r2/hardware/tools/avrdude -C/home/XXX/arduino-1.5.6-r2/hardware/tools/avrdude.conf -v -v -v -v -patmega32u4 -cavr109 -P/dev/ttyACM0 -b57600 -D -Uflash:w:/tmp/build2131402120248722624.tmp/sketch_feb26a.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 9 2011 at 16:00:41
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/home/XXX/arduino-1.5.6-r2/hardware/tools/avrdude.conf"
User configuration file is "/home/XXX/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: Recv: C [43]
avrdude: Recv: A [41] T [54] E [45] R [52] I [49] N [4e]
avrdude: Send: V [56]
avrdude: Recv: 1 [31] 0 [30]
avrdude: Send: v [76]
avrdude: Recv: ? [3f]
avrdude: Send: p [70]
avrdude: Recv: S [53]
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.[/size]
And so on..
But when I try to use the command from the terminal, I get error. The verbose output is exactly the same until it doesn't receive any response:
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
What can possibly cause this? Should I erase the bootloader and put Atmel's default bootloader to it and try again?
