I a currently working on a low-power embedded project for which I got a Pro Mini 168PA (8MHz, 3.3V) - see close-up photo for the details.
I installed the MiniCore board library in Arduino IDE to use it. I configured the board - see 2nd attachment.
First I tried programming it with an USB programmer (based on a Prolific P2303HXA, unfortunately without exposed DTR pin. That, alas, didn't work. I suppose the boot loader was missing.
Then I tried the "Arduino as ISP" approach depicted on this page. The probe wires use the same color scheme as in that article.
I configured the IDE as in the 2nd attachment and whenever I try to upload the boot loader, I get the following error:
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/shutterfreak/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.5/avrdude.conf -v -patmega168p -cstk500v1 -P/dev/cu.wchusbserial14110 -b19200 -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd5:m -Ulfuse:w:0b11110111:m
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/shutterfreak/Library/Arduino15/packages/MiniCore/hardware/avr/2.0.5/avrdude.conf"
User configuration file is "/Users/shutterfreak/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.wchusbserial14110
Using Programmer : stk500v1
Overriding Baud Rate : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x15
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x15
AVR Part : ATmega168P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x14
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x02
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0x10
Hardware Version: 97994043
Firmware Version: -370433968.32766
Topcard : STK502
Vtarget : 1.8 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: stk500_initialize(): (b) protocol error, expect=0x10, resp=0x01
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x10
avrdude done. Thank you.
Error while burning bootloader.
What else can I do?
