Pro Mini 5V 16MHz
hi @all
i have this Mini: my Pro Mini
my question does someone know if the V anG pin near the Reset Button (on the opposite of the Right Angle Header letters) are VCC and GND as Input with 5V or anything else? Because i'm wondering if there is a 3,3 V output pin or not?
thx for helping
hape
I would guess it's Vcc an GND indeed. But just get your multi meter out and check with a continuity test.
A 5V Pro Mini does not have a 3V3 out.
The G is definitely ground, you can clearly see the thermals on the sides of it connecting it to the ground plane.
