I am new to the forum thing so bear with me..
I have an arduino pro mini and I usually use an UNO to program the boards. Recently I purchased an FT232RL USB to TTL module to rid of some bulkiness. Although I have not been able to successfully finish uploading a sketch.
I'm running windows 7 and I installed the drivers from FTDI web site.
pins are hooked up like so.
pro mini - FTDI module
BLK - GND
GND - CTS
VCC - VCC
RXI - TXD
TXO - RXD
GRN - DTR
My pro mini has an onboard cap and the FTDI seems to have auto reset. When I upload a sketch things go well untill its almost done writing the sketch then I get errors. Although when trying to upload a blink sketch, the pro mini will blink as if the sketch was uploaded just fine.
I turned on the verbose during upload and this is what I get.
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\Diablo\AppData\Local\Temp\build6925953685312156608.tmp/Blink.cpp.hex"
avrdude: writing flash (1030 bytes):
Writing | ############################################avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I have not found anything like this. Any Thoughts?
Thanks
