this is my first topic in this forum.
I want to play music with arduino,So I use vs1003 module.
And I download this library from github:
It works correctly in case of HelloMP3 array.
and here is HelloMP3 hex array of music:
unsigned char HelloMP3[] = {
0xFF,0xF2,0x40,0xC0,0x19,0xB7,0x00,0x14,0x02,0xE6,0x5C, /* ..@.......\ */
0x01,0x92,0x68,0x01,0xF1,0x5E,0x03,0x08,0xF0,0x24,0x80, /* ..h..^...$. */
0x05,0x9E,0x20,0xC6,0xFC,0x12,0x32,0x5C,0xBF,0xF9,0xB9, /* .. ...2\... */
0x20,0x4A,0x7F,0x85,0xEC,0x4C,0xCD,0xC7,0x27,0xFE,0x5C, /* J...L..'.\ */
0x34,0x25,0xCB,0xE6,0xFF,0xFF,0x8E,0x42,0xE1,0xA0,0x5E, /* 4%.....B..^ */
0xCA,0x6E,0x30,0x9F,0xFF,0xF8,0xC2,0x12,0x84,0xB9,0x7C, /* .n0.......| */
0xDC,0x61,0x09,0x4A,0x7F,0xFF,0xFF,0xF9,0x7D,0x32,0x51, /* .a.J....}2Q */
0x09,0x7C,0xE1,0xA5,0x6E,0xB4,0xFF,0xFF,0xFF,0xFF,0xD3, /* .|..n...... */
but when I want to read MP3 from my SDcard I hear nothing and here is my code:
#include <LiquidCrystal.h>
#include <SD.h>
vs1003_hello
A simple MP3 flow player to test if board and library are working together.
The following sketch should say "Hello" every 0.5s :)
Created 2012-04-05 by Andrey Karpov
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <avr/io.h>
#include <Arduino.h>
#include "printf.h"
#include <VS1003.h>
#include <SPI.h>
VS1003 player(28, 29, 30, 31); // cs_pin, dcs_pin, dreq_pin, reset_pin
File my_file1;
File my_file2;
LiquidCrystal lcd(22,23,24,25,26,27);
unsigned char buffer[512];
void setup () {
lcd.begin(16,2);
pinMode(53,OUTPUT);
if(SD.begin(53)==true)
lcd.print("init ok");
lcd.print("init fail");
if(SD.exists("3.mp3")==true)
lcd.clear();
lcd.print("exist ok!");
lcd.clear();
lcd.print("not exist");
// initiate SPI
SPI.begin();
// initiate a player
player.begin();
// set maximum output volume
player.setVolume(0x00);
my_file1=SD.open("3.mp3",FILE_READ);
lcd.clear();
if(my_file1)
for(int i=0;i<my_file1.available();i++)
buffer[i]=my_file1.read();
//delay(5000);
lcd.print("error in opening");
my_file1.close();
player.playChunk(buffer, sizeof(buffer));
thanks for your help.I got crazy!!! :o
