Problem burning bootloader to Nano clone
I recently got a Nano clone and I found that sketches couldn't be uploaded. after looking around for a while I found that I needed to burn a bootloader to the chip; however I'm getting the following error:
Avrdude version 8.0-arduino.1
Copyright see https://github.com/avrdudes/avrdude/blob/main/AUTHORS
System wide configuration file is C:\Users\ismaw\AppData\Local\Arduino15\packages\MiniCore\tools\avrdude\8.0-arduino.1\etc\avrdude.conf
Using port            : COM5
Using programmer      : stk500v1
Setting baud rate     : 19200
AVR part              : ATmega328PB
Programming modes     : SPM, ISP, HVPP, debugWIRE
Programmer type       : STK500
Description           : Atmel STK500 v1
HW Version            : 2
FW Version            : 1.18
Topcard               : Unknown
Vtarget               : 0.0 V
Varef                 : 0.0 V
Oscillator            : Off
SCK period            : 0.0 us
XTAL frequency        : 7.372800 MHz
AVR device initialized and ready to accept instructions
Device signature = FF 00 00
Error: expected signature for ATmega328PB is 1E 95 16
  - double check chip or use -F to carry on regardless
Avrdude done.  Thank you.
Failed chip erase: uploading error: exit status 1
The device signature changes between trials. It could sometimes be 00 FF 00 for example.
I'm using an Arduino Mega as the programmer
So far I have done the following:
  • Installed the MiniCore boards
  • Chose 328PB as the variant (other variants also do not work)
  • Connected a 10uF capacitor from RESET to GND on the Mega (I also tried 100nF and 1uF and they both didn't work)
  • Connected an external 16MHz clock to the Nano between pins 9 and 10
I really couldn't find any other solutions online :frowning:
Some thoughts:
  • I once had a cheap Nano clone with USB mini connector that didn't have the 328P processor, but a 168 instead.
  • make sure that your connections are stable
  • perhaps some other fuse got set, preventing you to upload. Using a high voltage fuse reset may be helpful.
Does your nano have a 328PB on it?
That makes no sense, they are GPIO pins
Yes, that's what it says on the chip at least
This was a proposed solution in another forum post, here is the quote:
You misunderstood what he meant.
If you press the reset button does the LED blink about 3 times?
Sorry for the misunderstanding. The LED blinks only once when I reset it
Did you select the following when burning the bootloader?
Clock: External 16MHz
BOD: 2.7V
Variant: 328PB
Bootloader: Yes (UART0)
Baud rate: Default
Yes, I unfortunately still get the same error. I also tried selecting "Yes (UART1 328PB only)" and "No bootloader" with no luck.
Since you said that you initially could not upload sketches, your nano may just be defective.
At this point all I can say is recheck the wiring.
Thank you so much for your help.
The fix was actually pretty simple. I was following an old guide that connected the ICSP RESET pin to pin 53 on the Mega, but it worked when I connected it to pin 10 instead as stated in the ArduinoISP sketch, my bad for not noticing that.
