Problem burning bootloader\ uploading sketch: avrdude: verification error; content mismatch
Hello everyone,
I have an Arduino clone from AzDelivery and try to reuse it. Since uploading a new sketch was not possible anymore I tried burning the bootloader again and uploading the standard 'blink' sketch.
I used an original UNO as programmer with help from this article. My programming setup is
Writing | ################################################## | 100% 0.01s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3F:
avrdude: load data lock data from input file 0x3F:
avrdude: input file 0x3F contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.01s
avrdude: verifying ...
avrdude: 1 bytes of lock verified
avrdude: reading input file "0xFD"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0xFD:
avrdude: load data efuse data from input file 0xFD:
avrdude: input file 0xFD contains 1 bytes
avrdude: reading on-chip efuse data:
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDA"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDA:
avrdude: load data hfuse data from input file 0xDA:
avrdude: input file 0xDA contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done.  Thank you.
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\z004447n\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : stk500v1
         Overriding Baud Rate          : 19200
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : STK500
         Description     : Atmel STK500 Version 1.x firmware
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "C:\Users\z004447n\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex"
avrdude: writing flash (32670 bytes):
Writing | ################################################## | 100% -0.00s
avrdude: 32670 bytes of flash written
avrdude: verifying flash memory against C:\Users\z004447n\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: load data flash data from input file C:\Users\z004447n\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex:
avrdude: input file C:\Users\z004447n\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/atmega/ATmegaBOOT_168_atmega328.hex contains 32670 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% -0.00s
avrdude: 32670 bytes of flash verified
avrdude: reading input file "0x0F"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.02s
avrdude: verifying lock memory against 0x0F:
avrdude: load data lock data from input file 0x0F:
avrdude: input file 0x0F contains 1 bytes
In the past this was enough to get a 'clean' Nano. Uploading a sketch (after setting the IDE back to "AVRISP mkll") yields following result
Reading | #####################################Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
############# | 100% 0.22s
avrdude: verification error, first mismatch at byte 0x0200
         0xff != 0x88
I am not sure what this means. Is the bootloader burned correctly? Is the device ready for upload?
Googling yielded unsatisfactory results (result1, result2)
  • Multiple reburning had no effect
  • Reuploading the ArduinoISP sketch to the UNO had no effect
  • Rewiring had no effect
I burned and uploaded multiple Nanos today and one gives me troubles. Since some kind of communication is happening between the UNO and Nano (blinking while burning) I do not believe the device is lost, but can not figure out what the error is.
Nope !
I do have to reset my UNO at times to start the ArduinISP sketch again
If it's just that one, probably it is not working properly anymore and it's a hardware issue of some kind.
I also tried to upload the "Blink" sketch directly via the ISP
Setting the Board to the NANO
Setting the Port the the UNO (Programmer)
Programmer is still "Arduino as ISP"
Then upload using programmer: Upload successful!
The NANO still works!
How can I tell? The output does not return an error or a message that the wrong bootloader is loader.
I now flashed 15 Devices (cheap copies of a cheap copy) for my prototype CAN-network and everyone of them works fine:
  • Burn bootloader
  • Upload sketch via serial
The 'faulty' Nano is marked with ISP and will hopefully reused in another project
I have to bring the topic up again.
Over the weekend I sorted my uC's and wanted to check my unused original Arduinos (3xUnos, 5xNanos, 1xMega,...). The UNOs worked out of the box (example->Blink). The Nanos did not have a working bootloader since I was unable to upload any code. I tried both Nano-processors ATmega328P, ATmega32P (old bootloader) and even with the platform
UNO*.
Therefore I tried to burn the bootloader with the tutorials above. I tried the bootloader for
  • Atmega328P
  • Atmega328P (old bootloader)
  • UNO
         System wide configuration file is "/etc/avrdude.conf"
         Using Port                    : COM5
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: reading input file "0x3F"
/bin/avrdude -/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
         Using Port                    : COM5
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: reading input file "\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex"
avrdude: writing flash (32768 bytes):
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against \AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: load data flash data from input file \AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex:
avrdude: input file \AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
Reading | ################################################## | 100% 0.00s
avrdude: 32768 bytes of flash verified
The output window acknowledges the process -> done burning bootloader.
None of the original Nanos were able to upload sketches after the burning of the bootloader. I tried every variation I can think of:
  • ArduinoIDE (burn as Atmega328P, old bootloader UNO)
  • VSCode w PlatformIO (burn as Atmega328P, old bootloader UNO)
  • On Win10, Ubuntu 20.04, Ubuntu 16.10
The results were the same -> unable to upload sketches via serial upload.
Now the odd thing: Programming the sketch via the UNO over ISP works. The serial monitor return the correct values also.
I am not sure if I am missing something or if there is a bug in the ISP-sketch or the burning process. I also have no indication that the burning process went wrong or that any of the hardware is defect.
