Hello
I need help with my project. It is basically a robot that needs to follow a line, but a the end of the line (when no sensors see a line) the robot has to start a other sequence, which is finding an object with an ultrasonic sensor. (right now it can only measure the distance)
I have 2 seperate codes that both work separately with my robot. But when I want to merge them together I get error's.
I would really appreciate any help or interest!
I wish to combine 2 codes using following code;
bool lijnVolgen = true;
// SETUP1
// SETUP2
if(lijnVolgen == true){
//PROGRAM1
if(out1==1 && out2==1 && out3==1 && out4==1 && out5==1){ // When none of the 5 IR-sensors see a line
lijnVolgen = false;
}else if(lijnVolgen == false){
// PROGRAM 2
Here are the 2 codes I want to combine;
CODE1: line following
#define RECHTS_DIR 13
#define RECHTS_SPEED 11
#define RECHTS_BRAKE 8
#define LINKS_DIR 12
#define LINKS_SPEED 3
#define LINKS_BRAKE 9
#define SENSOR_1 2
#define SENSOR_2 4
#define SENSOR_3 5
#define SENSOR_4 10
#define SENSOR_5 A2
#define VOORUIT HIGH
#define ACHTERUIT LOW
int out1=0;
int out2=0;
int out3=0;
int out4=0;
int out5=0;
pinMode(LINKS_DIR, OUTPUT);
pinMode(LINKS_SPEED, OUTPUT);
pinMode(LINKS_BRAKE, OUTPUT);
pinMode(RECHTS_DIR, OUTPUT);
pinMode(RECHTS_SPEED, OUTPUT);
pinMode(RECHTS_BRAKE, OUTPUT);
pinMode(SENSOR_1, INPUT);
pinMode(SENSOR_2, INPUT);
pinMode(SENSOR_3, INPUT);
pinMode(SENSOR_4, INPUT);
pinMode(SENSOR_5, INPUT);
digitalWrite(LINKS_BRAKE, LOW);
digitalWrite(RECHTS_BRAKE, LOW);
out1 = digitalRead(SENSOR_1);
out2 = digitalRead(SENSOR_2);
out3 = digitalRead(SENSOR_3);
out4 = digitalRead(SENSOR_4);
out5 = digitalRead(SENSOR_5);
if(out3==0 && out1==1 && out2==1 && out4==1 && out5==1) // Als middensensor alleen lijn ziet (voorwaarde andere sensoren zien geen lijn toegevoegd)
analogWrite(LINKS_SPEED,255); //beide motors maximum
analogWrite(RECHTS_SPEED,255);
digitalWrite(LINKS_DIR, VOORUIT);
digitalWrite(RECHTS_DIR, VOORUIT);
else if(out4==0 && out3==1) // als rechts4 lijn ziet maar midden niet (kleine bocht)
if(out3 != 0)
digitalWrite(RECHTS_DIR, ACHTERUIT);
else if(out4==0 && out3==0) // als middensensor lijn ziet en rechts4 (erg kleine bocht)
if(out4 != 1)
else if(out5 ==0 && out3==1) // als rechts5 lijn ziet en midden niet (scherpe bocht)
if(out3 != 0)
analogWrite(RECHTS_SPEED,220);
analogWrite(LINKS_SPEED,220);
else if(out5==0 && out3==0) // als rechts5 lijn ziet en midden lijn ziet (ERG SCHERP)
if(out5 != 1)
if(out5 != 1)
else if(out2==0 && out3==1) // als links2 lijn ziet maar midden niet
if(out3 != 0)
digitalWrite(LINKS_SPEED,220);
digitalWrite(LINKS_DIR, ACHTERUIT);
else if(out2==0 && out3==0) // als links2 lijn ziet en midden ook
if(out2 != 1)
else if( out2==0 && out1==0) // als links2 lijn ziet en links1 ook (redelijk scherpe bocht)
if(out3 !=0)
else if(out1==0) // als links1 alleen lijn ziet (erg scherpe bocht)
if(out3 !=0)
else if(out1==1 && out2==1 && out3==1 && out4==1 && out5==1) // als alle sensors geen lijn zien
digitalWrite(RECHTS_SPEED,LOW);
digitalWrite(LINKS_SPEED,LOW);
delay(30);
CODE2: distance measuring
#include "URMSerial.h"
#include <SoftwareSerial.h>
// The measurement we're taking
#define DISTANCE 1
#define TEMPERATURE 2
#define ERROR 3
#define NOTREADY 4
#define TIMEOUT 5
URMSerial urm;
Serial.begin(9600); // Sets the baud rate to 9600
urm.begin(7,6,9600); // RX Pin, TX Pin, Baud Rate
Serial.println("URM37 Library by Miles Burton"); // Shameless plug
Serial.print("Measurement: ");
Serial.println(getMeasurement()); // Output measurement
delay(50);
int value; // This value will be populated
int getMeasurement()
// Request a distance reading from the URM37
switch(urm.requestMeasurementOrTimeout(DISTANCE, value)) // Find out the type of request
case DISTANCE: // Double check the reading we recieve is of DISTANCE type
// Serial.println(value); // Fetch the distance in centimeters from the URM37
return value;
case TEMPERATURE:
return value;
case ERROR:
Serial.println("Error");
case NOTREADY:
Serial.println("Not Ready");
case TIMEOUT:
Serial.println("Timeout");
return -1;
They both work separately but when I combine them I get an error's.
Can someone please give me advice on how to do this?
