Need help combining codes
Arduino: 1.8.16 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Jlo\Documents\Arduino\capston\capstonedraft\capstonedraft.ino: In function 'void loop()':
capstonedraft:51:13: error: 'Stop' was not declared in this scope
         Stop(); //Initialize with motors stoped.
C:\Users\Jlo\Documents\Arduino\capston\capstonedraft\capstonedraft.ino:51:13: note: suggested alternative: 'loop'
         loop
capstonedraft:54:17: error: 'forward' was not declared in this scope
             forward();
C:\Users\Jlo\Documents\Arduino\capston\capstonedraft\capstonedraft.ino:54:17: note: suggested alternative: 'fread'
             forward();
             fread
capstonedraft:57:17: error: 'back' was not declared in this scope
             back();
capstonedraft:60:17: error: 'left' was not declared in this scope
             left();
capstonedraft:63:17: error: 'right' was not declared in this scope
             right();
capstonedraft:66:17: error: 'forwardleft' was not declared in this scope
             forwardleft();
capstonedraft:69:17: error: 'forwardright' was not declared in this scope
             forwardright();
capstonedraft:72:17: error: 'backleft' was not declared in this scope
             backleft();
capstonedraft:75:17: error: 'backright' was not declared in this scope
             backright();
capstonedraft:113:15: error: 'brakeOn' was not declared in this scope
           brakeOn();
C:\Users\Jlo\Documents\Arduino\capston\capstonedraft\capstonedraft.ino:113:15: note: suggested alternative: 'brakeTime'
           brakeOn();
           brakeTime
capstonedraft:117:15: error: 'brakeOff' was not declared in this scope
           brakeOff();
C:\Users\Jlo\Documents\Arduino\capston\capstonedraft\capstonedraft.ino:117:15: note: suggested alternative: 'brkonoff'
           brakeOff();
           brkonoff
capstonedraft:123:1: error: a function-definition is not allowed here before '{' token
capstonedraft:129:1: error: a function-definition is not allowed here before '{' token
capstonedraft:135:1: error: a function-definition is not allowed here before '{' token
capstonedraft:141:2: error: a function-definition is not allowed here before '{' token
capstonedraft:146:1: error: a function-definition is not allowed here before '{' token
capstonedraft:151:1: error: a function-definition is not allowed here before '{' token
capstonedraft:156:1: error: a function-definition is not allowed here before '{' token
capstonedraft:161:1: error: a function-definition is not allowed here before '{' token
capstonedraft:167:1: error: a function-definition is not allowed here before '{' token
capstonedraft:175:1: error: a function-definition is not allowed here before '{' token
capstonedraft:201:1: error: a function-definition is not allowed here before '{' token
capstonedraft:203:1: error: expected '}' at end of input
exit status 1
option enabled in File -> Preferences.
#define in1 3 //L298n Motor Driver pins.
#define in2 10
#define in3 4
#define in4 5
#define LED 13
// l298n motor driver
int command; //Int to store app command state.
int Speed = 204; // 0 - 255.
int Speedsec;
int buttonState = 0;
int lastButtonState = 0;
int Turnradius = 0; //Set the radius of a turn, 0 - 255 Note:the robot will malfunction if this is higher than int Speed.
int brakeTime = 45;
int brkonoff = 1; //1 for the electronic braking system, 0 for normal.
//end
//motor driver
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(LED, OUTPUT); //Set the LED pin.
if (Serial.available() > 0)
command = Serial.read();
switch (command) {
case 'F':
forward();
Your code seems incomplete
If that's all the code you have..
Go back and get the rest, you're missing quite a bit..
sorry.. ~q
can you help me combines these code because i keep getting a not declared error when i combine
code 1
#define in1 5 //L298n Motor Driver pins.
#define in2 6
#define in3 10
#define in4 11
#define LED 13
int Speedsec;
int brakeTime = 45;
  Serial.begin(9600);  //Set the baud rate to your Bluetooth module.
  if (Serial.available() > 0) {
    switch (command) {
      case 'F':
        forward();
      case 'B':
        back();
      case 'L':
        left();
      case 'R':
        right();
      case 'G':
        forwardleft();
      case 'I':
        forwardright();
      case 'H':
        backleft();
      case 'J':
        backright();
      case '0':
        Speed = 100;
      case '1':
        Speed = 140;
      case '2':
        Speed = 153;
      case '3':
        Speed = 165;
      case '4':
        Speed = 178;
      case '5':
        Speed = 191;
      case '6':
        Speed = 204;
      case '7':
        Speed = 216;
      case '8':
        Speed = 229;
      case '9':
        Speed = 242;
      case 'q':
        Speed = 255;
    Speedsec = Turnradius;
    if (brkonoff == 1) {
      brakeOn();
      brakeOff();
void forward() {
  analogWrite(in1, Speed);
  analogWrite(in3, Speed);
void back() {
  analogWrite(in2, Speed);
  analogWrite(in4, Speed);
void left() {
void right() {
void forwardleft() {
  analogWrite(in1, Speedsec);
void forwardright() {
  analogWrite(in3, Speedsec);
void backright() {
  analogWrite(in4, Speedsec);
void backleft() {
  analogWrite(in2, Speedsec);
void Stop() {
  analogWrite(in1, 0);
  analogWrite(in2, 0);
  analogWrite(in3, 0);
  analogWrite(in4, 0);
void brakeOn() {
  //Here's the future use: an electronic braking system!
  // read the pushbutton input pin:
  buttonState = command;
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == 'S') {
      if (lastButtonState != buttonState) {
        digitalWrite(in1, HIGH);
        digitalWrite(in2, HIGH);
        digitalWrite(in3, HIGH);
        digitalWrite(in4, HIGH);
        delay(brakeTime);
        Stop();
    // save the current state as the last state,
    //for next time through the loop
    lastButtonState = buttonState;
void brakeOff() {
code2
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
const int TrigPin = 8;
const int EchoPin = 9;
float cm;
float ft;
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  pinMode(TrigPin, OUTPUT);
  pinMode(EchoPin, INPUT);
   for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay (50);                       // waits 15ms for the servo to reach the position
   // ultrasonic sensor
    delay (500);
    digitalWrite(TrigPin, LOW);
    delayMicroseconds(2);
    digitalWrite(TrigPin, HIGH);
    delayMicroseconds(10);
    cm = pulseIn(EchoPin, HIGH) / 58.0; //The echo time is converted into cm
    cm = (int(cm * 100.0)) / 100.0;     //Keep two decimal places
    Serial.print("Distance\t=\t");
    Serial.print(cm);
    Serial.print("cm");
   for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
    delay(50);                       // waits 15ms for the servo to reach the position
    //ultrasonic sensor
    delay (500);
    Serial.print(cm);
    Serial.print("cm");
thank you
Please post your best attempt at combining the 2 sketches
Post an annotated schematic showing all connections, power, ground and power source. Also post links to technical information on each of the hardware devices.
There are, most likily, missing or misplaced curly brackets ({ }) in the code (at a minimum). But there is no way to help you unless you post the entire code. When you do post the code we will have to copy the code to a text editor for examination and/or the IDE to verify the code to try to fix the errors. If you, please, post the code properly in a code block (code tags) it will make it much easier for us to copy.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format). That will often make the location of missing or misplaced brackets obvious.
If you read and follow the guidelines you will get faster and better help.
i just reattempted to combine them in a fresh sketch and no error
if inquire an error i will post on here again
i combined them but now my motor doesnt work it doest drive now but the code doest have an error
#define in2 10
#define in3 4
#define in4 5
#define LED 13
//servo
#include <Servo.h>
//ultrasonic sensor
float cm;
float ft;
//l298 motor driver
int Speedsec;
int brakeTime = 45;
 //servo
  //ultrasonic sensor
  //motor driver
    //servo
    delay (500);
    Serial.print(cm);
    Serial.print("cm");
     //servo
    //ultrasonic sensor
    delay (500);
    Serial.print(cm);
    Serial.print("cm");
   //motor driver
    switch (command) {
      case 'F':
        forward();
      case 'B':
        back();
      case 'L':
        left();
      case 'R':
        right();
      case 'G':
        forwardleft();
      case 'I':
        forwardright();
      case 'H':
        backleft();
      case 'J':
        backright();
      case '0':
        Speed = 100;
      case '1':
        Speed = 140;
      case '2':
        Speed = 153;
      case '3':
        Speed = 165;
      case '4':
        Speed = 178;
      case '5':
        Speed = 191;
      case '6':
        Speed = 204;
      case '7':
        Speed = 216;
      case '8':
        Speed = 229;
      case '9':
        Speed = 242;
      case 'q':
        Speed = 255;
      brakeOn();
      brakeOff();
void forward() {
void back() {
void left() {
void right() {
void backright() {
void backleft() {
void Stop() {
void brakeOn() {
        delay(brakeTime);
        Stop();
void brakeOff() {
i combine my code to one program and now it doesnt drive
the code combines a servo motor, ultrasonic sensor and l298n motor driver as well as bluetooth hc06
everthing work except the bluetooth to the phone to drive the motor , the bluetooth does connect just doesnt drive
#define in2 10
#define in3 4
#define in4 5
#define LED 13
//servo
#include <Servo.h>
//ultrasonic sensor
float cm;
float ft;
//l298 motor driver
int Speedsec;
int brakeTime = 45;
 //servo
  //ultrasonic sensor
  //motor driver
    //servo
    delay (500);
    Serial.print(cm);
    Serial.print("cm");
     //servo
    //ultrasonic sensor
    delay (500);
    Serial.print(cm);
    Serial.print("cm");
   //motor driver
    switch (command) {
      case 'F':
        forward();
      case 'B':
        back();
      case 'L':
        left();
      case 'R':
        right();
      case 'G':
        forwardleft();
      case 'I':
        forwardright();
      case 'H':
        backleft();
      case 'J':
        backright();
      case '0':
        Speed = 100;
      case '1':
        Speed = 140;
      case '2':
        Speed = 153;
      case '3':
        Speed = 165;
      case '4':
        Speed = 178;
      case '5':
        Speed = 191;
      case '6':
        Speed = 204;
      case '7':
        Speed = 216;
      case '8':
        Speed = 229;
      case '9':
        Speed = 242;
      case 'q':
        Speed = 255;
      brakeOn();
      brakeOff();
void forward() {
void back() {
void left() {
void right() {
void backright() {
void backleft() {
void Stop() {
void brakeOn() {
        delay(brakeTime);
        Stop();
void brakeOff() {
Does the test code for the servo work? What servo & how is it powered? Many "servo no work" issues are power related. Pictures of the wiring and a hand drawn schematic would be helpful please.
doesn't the L298 have an enable pin?
while you could control a motor using the IN1/2 pins with the EN pin set HIGH, those pins would need to be connect to arduino PWM pins (looks like pin 4 is not a PWM pin).
when using the IN1/2 pins, one would be set LOW and the other controlled with a PWM signal using analogWrite().
both forward() and reverse() driver different IN1/IN2 pins, but they don't set the other pins to zero. shouldn't forward be
void forward() {
    analogWrite(in2,0);
    analogWrite(in4,0);
have you flagged it?
I have merged your topics due to them having too much overlap on the same subject matter @larenzia93.
In the future, please only create one topic for each distinct subject matter and be careful not to cause them to converge into parallel discussions.
The reason is that generating multiple threads on the same subject matter can waste the time of the people trying to help. Someone might spend a lot of time investigating and writing a detailed answer on one topic, without knowing that someone else already did the same in the other topic.
Thanks in advance for your cooperation.
yes its not the servo its the l298 motor driver and bluetooth
yes but i have 2 jumpers on them
it works as is seperately
all codes work separately and they all have different pin
From the Servo library reference:
On boards other than the Mega, use of the library disables analogWrite() (PWM) functionality on pins 9 and 10, whether or not there is a Servo on those pins.
Having the Bluetooth module and serial monitor both connected to pins 0 and 1 may not work well. There should be only 1 thing connected to a serial port. I would suggest that you use a software serial port , on different pins than 0 & 1, for the Bluetooth module and save the hardware serial port for program upload and program output and debugging.
how would i rewrite that in the code if i change the blue tooth 0 and 1 to different pins?
Here is a Bluetooth test program showing how to set up with the SoftwareSerial library. Call the begin() function in setup and there after use the soft serial port just like a hardware serial port.
#include <SoftwareSerial.h>  // load the library
// Change these pins to what works for you.
// and connect the BT device to those pins
// BT RX to Arduino TX through voltage divider, BT TX to Arduino RX
SoftwareSerial btSerial(4, 7); // RX, TX
   btSerial.begin(9600);  // HC05 defaults to 9600 baud
   Serial.println("Arduino ready");
   btSerial.println("Arduino ready");
   // if something comes from serial monitor send it to the Bluetooth device
   if(Serial.available())
      btSerial.print(char(Serial.read()));
   // if the Bluetooth device sends something print it in serial monitor
   if(btSerial.available())
      Serial.print(char(btSerial.read()));
