Problem connecting Dallas 18B20 Nano RP2040
I only get temp -127 deg C when I try to use the sensor with a RP2040 Nano connect. If I move the sensor to an UNO board - same IO - and download the same sketch, it works fine. IO pin 12 (that ijust to make sure I havn't destraoyed this IO pin.
The wiring is as simple as it can be. The sensors black cable goes to ground, red to +3.3V and yellow to IO12. There is a pullup resistor (4,7k) between +3.3 and IO12
Any ideas?
You can't use the same code on Uno and RP2040 because different architecture.
Please show your code (RP2040 and Uno versions)
This is the code I am trying to use, found as an example of how to use a 18B20 with Arduino. I tried to use OneWire.h that was in the original example code but it crashed the Nano when downloading so I tried OneWireNg.h instead. This works for downloading but does not read the temperature (results in -127 deg C). The code works fine with the Uno board.
#include <OneWireNg.h>
#include <DallasTemperature.h>
// Data wire is conntec to the Arduino digital pin 12
#define ONE_WIRE_BUS 12
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature sensor
DallasTemperature sensors(&oneWire);
void setup(void)
  // Start serial communication for debugging purposes
  // Start up the library
  sensors.begin();
void loop(void){
  // Call sensors.requestTemperatures() to issue a global temperature and Requests to all devices on the bus
  sensors.requestTemperatures();
  Serial.print("Celsius temperature: ");
  // Why "byIndex"? You can have more than one IC on the same bus. 0 refers to the first IC on the wire
  Serial.println(sensors.getTempCByIndex(0));
-127 indicates no connection, and that may be all that is wrong, so look there first. It may be that a smaller pullup resistor, maybe 3.3k is more appropriate with a 3.3v Arduino, but I have not heard of it. The DS18B20 is good down to 3.0v.
using OneWireNg running File>Examples>OneWireNg>Arduino>DallasTemperature with the DS18B20 1-wire bus connected to pin 13 I get
28:FF:FC:2A:85:16:5:8A -> DS18B20
  Scratchpad: 63:1:4B:46:7F:FF:C:10:D1; Th:75; Tl:70; Resolution:12; Temp:22.187 C
  Scratchpad: 69:1:4B:46:7F:FF:C:10:7D; Th:75; Tl:70; Resolution:12; Temp:22.562 C
  Scratchpad: 71:1:4B:46:7F:FF:C:10:3; Th:75; Tl:70; Resolution:12; Temp:23.62 C
  Scratchpad: 78:1:4B:46:7F:FF:C:10:6A; Th:75; Tl:70; Resolution:12; Temp:23.500 C
  Scratchpad: 7E:1:4B:46:7F:FF:C:10:F9; Th:75; Tl:70; Resolution:12; Temp:23.875 C
  Scratchpad: 83:1:4B:46:7F:FF:C:10:A2; Th:75; Tl:70; Resolution:12; Temp:24.187 C
  Scratchpad: 88:1:4B:46:7F:FF:C:10:4D; Th:75; Tl:70; Resolution:12; Temp:24.500 C
  Scratchpad: 8B:1:4B:46:7F:FF:C:10:88; Th:75; Tl:70; Resolution:12; Temp:24.687 C
Could you provide me with the code you are using for this. I found this code at File>Examples>OneWireNg>Arduino>DallasTemperature but only get (moved my sensor to pin 13)
TIMESTAMP -> -----------
 * Copyright (c) 2019-2022 Piotr Stolarz
 * OneWireNg: Arduino 1-wire service library
 * Distributed under the 2-clause BSD License (the License)
 * see accompanying file LICENSE for details.
 * This software is distributed WITHOUT ANY WARRANTY; without even the
 * implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
 * See the License for more information.
 * Dallas family thermometers access example (Arduino).
 * Required configuration:
 * - @c CONFIG_SEARCH_ENABLED for non single sensor setup,
 * - @c CONFIG_PWR_CTRL_ENABLED if @c PWR_CTRL_PIN is configured.
#include "OneWireNg_CurrentPlatform.h"
#include "drivers/DSTherm.h"
#include "utils/Placeholder.h"
 * 1-wire bus pin number.
#ifndef OW_PIN
# define OW_PIN         13
#endif
 * If defined: sensors powered parasitically.
//#define PARASITE_POWER
 * If defined: only one sensor device is allowed to be connected to the bus.
 * The library may be configured with 1-wire search activity disabled to
 * reduce its footprint.
//#define SINGLE_SENSOR
 * For parasitically powered sensors the parameter specifies type of power
 * provisioning:
 * - Not defined: power provided by bus pin.
 * - Defined: power provided by a switching transistor and controlled by the
 *   pin number specified by the parameter.
//#define PWR_CTRL_PIN    9
 * If defined: set permanent, common resolution for all sensors on the bus.
 * Resolution may vary from 9 to 12 bits.
//#define COMMON_RES      (DSTherm::RES_12_BIT)
#if !defined(SINGLE_SENSOR) && !CONFIG_SEARCH_ENABLED
# error "CONFIG_SEARCH_ENABLED is required for non single sensor setup"
#endif
#if defined(PWR_CTRL_PIN) && !CONFIG_PWR_CTRL_ENABLED
# error "CONFIG_PWR_CTRL_ENABLED is required if PWR_CTRL_PIN is configured"
#endif
#if (CONFIG_MAX_SEARCH_FILTERS > 0)
static_assert(CONFIG_MAX_SEARCH_FILTERS >= DSTherm::SUPPORTED_SLAVES_NUM,
    "CONFIG_MAX_SEARCH_FILTERS too small");
#endif
#ifdef PARASITE_POWER
# define PARASITE_POWER_ARG true
#else
# define PARASITE_POWER_ARG false
#endif
static Placeholder<OneWireNg_CurrentPlatform> ow;
/* returns false if not supported */
static bool printId(const OneWireNg::Id& id)
    const char *name = DSTherm::getFamilyName(id);
    Serial.print(id[0], HEX);
    for (size_t i = 1; i < sizeof(OneWireNg::Id); i++) {
        Serial.print(':');
        Serial.print(id[i], HEX);
    if (name) {
        Serial.print(" -> ");
        Serial.print(name);
    return (name != NULL);
static void printScratchpad(const DSTherm::Scratchpad& scrpd)
    const uint8_t *scrpd_raw = scrpd.getRaw();
    Serial.print("  Scratchpad:");
    for (size_t i = 0; i < DSTherm::Scratchpad::LENGTH; i++) {
        Serial.print(!i ? ' ' : ':');
        Serial.print(scrpd_raw[i], HEX);
    Serial.print("; Th:");
    Serial.print(scrpd.getTh());
    Serial.print("; Tl:");
    Serial.print(scrpd.getTl());
    Serial.print("; Resolution:");
    Serial.print(9 + (int)(scrpd.getResolution() - DSTherm::RES_9_BIT));
    long temp = scrpd.getTemp();
    Serial.print("; Temp:");
    if (temp < 0) {
        temp = -temp;
        Serial.print('-');
    Serial.print(temp / 1000);
    Serial.print('.');
    Serial.print(temp % 1000);
    Serial.print(" C");
#ifdef PWR_CTRL_PIN
    new (&ow) OneWireNg_CurrentPlatform(OW_PIN, PWR_CTRL_PIN, false);
#else
    new (&ow) OneWireNg_CurrentPlatform(OW_PIN, false);
#endif
    DSTherm drv(ow);
    drv.filterSupportedSlaves();
#endif
#ifdef COMMON_RES
     * Set common resolution for all sensors.
     * Th, Tl (high/low alarm triggers) are set to 0.
    drv.writeScratchpadAll(0, 0, COMMON_RES);
     * The configuration above is stored in volatile sensors scratchpad
     * memory and will be lost after power unplug. Therefore store the
     * configuration permanently in sensors EEPROM.
    drv.copyScratchpadAll(PARASITE_POWER_ARG);
#endif
    DSTherm drv(ow);
    /* convert temperature on all sensors connected... */
    drv.convertTempAll(DSTherm::MAX_CONV_TIME, PARASITE_POWER_ARG);
#ifdef SINGLE_SENSOR
    /* single sensor environment */
     * Scratchpad placeholder is static to allow reuse of the associated
     * sensor id while reissuing readScratchpadSingle() calls.
     * Note, due to its storage class the placeholder is zero initialized.
    static Placeholder<DSTherm::Scratchpad> scrpd;
    OneWireNg::ErrorCode ec = drv.readScratchpadSingle(scrpd);
    if (ec == OneWireNg::EC_SUCCESS) {
        printId(scrpd->getId());
        printScratchpad(scrpd);
    } else if (ec == OneWireNg::EC_CRC_ERROR)
        Serial.println("  CRC error.");
#else
    /* read sensors one-by-one */
    for (const auto& id: *ow) {
        if (printId(id)) {
            if (drv.readScratchpad(id, scrpd) == OneWireNg::EC_SUCCESS)
                Serial.println("  Read scratchpad error.");
#endif
    Serial.println("----------");
the program was File>Examples>OneWireNg>Arduino>DallasTemperature with the DS18B20 1-wire bus connected to pin 13 - no changes made to code
#ifndef OW_PIN
# define OW_PIN         13
#endif
 * provisioning:
#endif
#endif
#endif
#else
#endif
        Serial.print(':');
    if (name) {
        Serial.print(name);
    if (temp < 0) {
        temp = -temp;
        Serial.print('-');
    Serial.print('.');
    Serial.print(" C");
#ifdef PWR_CTRL_PIN
#else
#endif
    DSTherm drv(ow);
#endif
#ifdef COMMON_RES
#endif
    DSTherm drv(ow);
#else
        if (printId(id)) {
#endif
serial monitor output
what serial monitor output do you get?
looking at your photo and the rp2040-01-technical-reference pinout it looks like you have connected the DS18B20 1-wire bus connected to pin D13 which is GPIO6
GPIO13 is connected to pin D19
try changing the pin definition in your code to use GPIO6
#ifndef OW_PIN
# define OW_PIN         6
#endif
or move the DS18B20 1-wire bus to D19 to use GPIO13
avoid posting images of screen shots and serial output - images take a lot of space and cannot be copied from
post using code tags -select < CODE/ > and paste text where it says “type or paste code here”
