Problem connecting to firebase using nodemcu esp8266 and gas sensor
hi.... i want to send data from sensor to firebase... I am using esp8266 to connect to wifi ... There is no error when i compile the code and I am connected to the internet using esp8266. The data reading from gas sensor also visible in the serial monitor.. However there is no data in my firebase.. The firebase are connected but there is no data added. This is my first time doing an Iot project using arduino ide so im not quite sure about what im doing
This is my code for wifi and firebase connection
#include "ThingSpeak.h"
#include <ESP8266WiFi.h>
#include <FirebaseArduino.h>
#include <ArduinoJson.h>
#include <ESP8266HTTPClient.h>
#define FIREBASE_HOST " "
#define FIREBASE_AUTH " "
//--------Wi-Fi Details -----//
char ssid[] = " ";  //SSID
char pass[] = " "; //Password
unsigned long Channel_ID = ; // Channel ID
const char * myWriteAPIKey = " "; // Write API Key
const int Field_Number_1 = 1;
const int Field_Number_2 = 2;
String value = "";
String val1, val2;
int value_1 = 0, value_2 = 0;
WiFiClient  client;
  WiFi.mode(WIFI_STA);
  ThingSpeak.begin(client);
  internet();
  Firebase.begin(FIREBASE_HOST, FIREBASE_AUTH);
  internet();
  if (Serial.available() > 0)
    delay(100);
    while (Serial.available() > 0)
      value = Serial.readString();
      if (value[0] == '*')
        if (value[5] == '#')
          value_1 = ((value[1] - 0x30) * 10 + (value[2] - 0x30));
          value_2 = ((value[3] - 0x30) * 10 + (value[4] - 0x30));
  upload();
  val1 = String(value_1);
  val2 = String(value_2);
  Serial.print ("CARBON MONOXIDE: "); Serial.print (val1);
  String firebaseCo = String (val1) + String ("ppm");
  Serial.print ("ppm ; SMOKE: "); Serial.print (val2); Serial.println ("ppm");
  String firebaseSmoke = String (val2) + String ("ppm");
  delay (5000);
  Firebase.pushString ("CARBON MONOXIDE", firebaseCo);
  Firebase.pushString ("SMOKE", firebaseSmoke);
void internet()
  if (WiFi.status() != WL_CONNECTED)
    while (WiFi.status() != WL_CONNECTED)j
      WiFi.begin(ssid, pass);
      delay(5000);
void upload()
  ThingSpeak.writeField(Channel_ID, Field_Number_1, value_1, myWriteAPIKey);
  delay(15000);
  ThingSpeak.writeField(Channel_ID, Field_Number_2, value_2, myWriteAPIKey);
  delay(15000);
  value = "";
This is my arduino code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2,3);
#define load_Res 10
#define air_factor 9.83
int buzzer = 13;
int mq2 = A0;
int mq9 = A1;
float R0 = 0.91;
float m = -0.4678;
float b = 1.31;
float SmokeCurve[3] ={2.3,0.53,-0.44};
float Res=0;
float ppm, result;
  mySerial.begin(9600);
  pinMode(buzzer, OUTPUT);
  pinMode(mq2, INPUT);
  pinMode(mq9, INPUT);
  Res = SensorCalibration();
 float sensor_volt;
 float RS_gas;
 float ratio;
 float sensorValue = analogRead(A1);
 sensor_volt = (sensorValue / 1024) * 5.0;
 RS_gas = (5.0 - sensor_volt) / sensor_volt;
 ratio = RS_gas / R0;
 double ppm_log = (log10(ratio)-b)/m; //Get ppm value in linear scale according to the the ratio value
 float ppm = pow(10, ppm_log); //Convert ppm value to log scale
 Serial.println("CO (ppm) = ");
 Serial.println(ppm);
 mySerial.println(ppm);
 if(ppm>1000)
      digitalWrite(buzzer, HIGH);
      delay(2000);
   digitalWrite(buzzer, LOW);
   float res=resistance(5,50);
   res/=Res;
   result=pow(10,(((log(res)-SmokeCurve[1])/SmokeCurve[2]) + SmokeCurve[0]));
   Serial.println("SMOKE (ppm) =");
   Serial.println(result);
   mySerial.println(result);
   Serial.print("\n");
   if(result>1000)
      delay(2000);
float resistance(int samples, int interval)
   int i;
   float res=0;
   for (i=0;i<samples;i++)
      int adc_value=analogRead(mq2);
      res+=((float)load_Res*(1023-adc_value)/adc_value);
      delay(interval);
   res/=samples;
   return res;
float SensorCalibration()
  int i;
  float val=0;
  val=resistance(50,500);
  val = val/air_factor;
  return val;
Please help me solve this cuz i dont know where i did wrong
