Good day, I wish to know how to send data in this format from esp8266 to firebase where the values of my sensors are a child of a key:
I have not tested the code due to connection issues but I plan to test it out once our net comes back. However, here it is for reference:
#include <DHT.h>
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
#include <Adafruit_BMP085.h>
#define seaLevelPressure_hPa 1013.25
#include <FirebaseArduino.h>
#define DHT_SENSOR_PIN D7 // The ESP8266 pin D7 connected to DHT22 sensor
#define DHT_SENSOR_TYPE DHT22
#define WATERLEVEL_SENSOR_PIN A0
#define ON_Board_LED 2
Adafruit_BMP085 bmp;
const char* ssid = "Sky_3DE8_26";
const char* password = "CK9nQQuS";
#define FIREBASE_AUTH "campana-beta-default-rtdb.firebaseio.com"
#define FIREBASE_HOST "AYggFep8b3HKX1ovWhDE7tJ6Qn2jsd9g06nOQulc"
WiFiClientSecure client;
DHT dht(DHT_SENSOR_PIN, DHT_SENSOR_TYPE);
dht.begin(); //--> Start reading DHT11 sensors
bmp.begin();
WiFi.begin(ssid, password); //--> Connect to your WiFi router
Serial.println("");
pinMode(ON_Board_LED,OUTPUT); //--> On Board LED port Direction output
digitalWrite(ON_Board_LED, HIGH); //--> Turn off Led On Board
//----------------------------------------Wait for connection
Serial.print("Connecting");
Serial.print(".");
//----------------------------------------Make the On Board Flashing LED on the process of connecting to the wifi router.
digitalWrite(ON_Board_LED, LOW);
delay(250);
delay(250);
digitalWrite(ON_Board_LED, HIGH); //--> Turn off the On Board LED when it is connected to the wifi router.
//----------------------------------------If successfully connected to the wifi router, the IP Address that will be visited is displayed in the serial monitor
Serial.println("");
Serial.print("Successfully connected to : ");
Serial.println(ssid);
Serial.print("IP address: ");
Firebase.begin(FIREBASE_AUTH, FIREBASE_HOST);
client.setInsecure();
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity();
float t = dht.readTemperature();
float p = bmp.readPressure();
float l = analogRead(WATERLEVEL_SENSOR_PIN);
float humi = dht.readHumidity();
float temperature_C = dht.readTemperature();
float pressure_Pa = bmp.readPressure();
float flood_level = analogRead(WATERLEVEL_SENSOR_PIN);
if ( isnan(temperature_C) || isnan(humi)) {
Serial.println("Failed to read from DHT sensor!");
Serial.print("Humidity: ");
Serial.print(humi);
Serial.print("%");
Serial.print(" | ");
Serial.print("Temperature: ");
Serial.print(temperature_C);
Serial.print("°C");
Serial.print("Pressure: ");
Serial.print(pressure_Pa);
Serial.print("Pa");
Serial.print("Flood Level Value: ");
Serial.print(flood_level);
Serial.println("");
Firebase.set("Humidity", h);
Firebase.set("Temperature", t);
Firebase.set("Pressure", p);
Firebase.set("Flood Level", l);
if(Firebase.failed()) {
Serial.print("Failed");
Serial.println(Firebase.error());
return;
Serial.println("Sent Data");
delay(5000);
This project is due in a few months, badly need responses as I have other things to fix
