Problem declaring variables
I'm just doing my first sketches and have an issue where I get a "sensorPin was not declared in this scope" alarm for the "Love Meter"example in the projects book.
I thought I was declaring the variable in the setup with "const int sesnorPin = A0; "
Thanks in advance for your help!
void setup() {{
const float baselineTemp = 20.0;}
Serial.begin(9600); //opens the serial port
for(int pinNumber = 2; pinNumber<5; pinNumber++){
pinMode(pinNumber, OUTPUT);
digitalWrite(pinNumber, LOW);
void loop(){
int sensorVal = analogRead(sensorPin);
Serial.print("Sensor Value: ");
Serial.print(sensorVal);
float voltage = (sensorVal/1024.0) * 5.0;
Serial.print("Volts: ");
Serial.print(voltage);
float temperature = (voltage - 0.5) * 100;
Serial.print("degrees C: ");
Serial.print(temperature);
if (temperature < baselineTemp+2);{
digitalWrite(2, LOW);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
else if (temperature >= baselineTemp+2 && temperature <baselineTemp+4);{
  digitalWrite(2, HIGH);
  digitalWrite(3, HIGH);
else if (temperature >= baselineTemp+6);{
  digitalWrite(4, HIGH);
delay(1);
}void setup() {{
void loop(){
delay(1);
You are declaring sesnorPin (spelling ?) in setup() so it will only be available in setup()
Later, in loop() you try to use a variable named sensorPin which was never declared anywhere
Move the declaration to the start of the program to make the variable available globally and correct the spelling
Ah jeez rookie error... Thank you very much!
