Problem esp32 "INA219 not connected"
Hello everyone,
I've encountered an issue while trying to connect an INA219 sensor to my ESP32. The serial monitor is displaying the message "INA219 not connected," and I'm unsure where the problem lies. Below, I have attached my code and the circuit diagram for reference. Thank you all in advance!
* Example sketch for the INA219_WE library
* This sketch shows how to use the INA219 module in continuous mode.
* Further information can be found on:
* https://wolles-elektronikkiste.de/ina219 (German)
* https://wolles-elektronikkiste.de/en/ina219-current-and-power-sensor (English)
#include <Wire.h>
#include <INA219_WE.h>
#define I2C_ADDRESS 0x42
#define PIN_POWER_METER_SCL 22
#define PIN_POWER_METER_SDA 21
/* There are several ways to create your INA219 object:
 * INA219_WE ina219 = INA219_WE(); -> uses Wire / I2C Address = 0x40
 * INA219_WE ina219 = INA219_WE(I2C_ADDRESS); -> uses Wire / I2C_ADDRESS
 * INA219_WE ina219 = INA219_WE(&Wire); -> you can pass any TwoWire object
 * INA219_WE ina219 = INA219_WE(&Wire, I2C_ADDRESS); -> all together
  Wire.begin(21,22);
  if(!ina219.init()){
    Serial.println("INA219 not connected!");
  /* Set ADC Mode for Bus and ShuntVoltage
  * Mode *            * Res / Samples *       * Conversion Time *
  BIT_MODE_9        9 Bit Resolution             84 Β΅s
  BIT_MODE_10       10 Bit Resolution            148 Β΅s
  BIT_MODE_11       11 Bit Resolution            276 Β΅s
  BIT_MODE_12       12 Bit Resolution            532 Β΅s  (DEFAULT)
  SAMPLE_MODE_2     Mean Value 2 samples         1.06 ms
  SAMPLE_MODE_4     Mean Value 4 samples         2.13 ms
  SAMPLE_MODE_8     Mean Value 8 samples         4.26 ms
  SAMPLE_MODE_16    Mean Value 16 samples        8.51 ms
  SAMPLE_MODE_32    Mean Value 32 samples        17.02 ms
  SAMPLE_MODE_64    Mean Value 64 samples        34.05 ms
  SAMPLE_MODE_128   Mean Value 128 samples       68.10 ms
  ina219.setADCMode( BIT_MODE_12); // choose mode and uncomment for change of default
  /* Set measure mode
  POWER_DOWN - INA219 switched off
  TRIGGERED  - measurement on demand
  ADC_OFF    - Analog/Digital Converter switched off
  CONTINUOUS  - Continuous measurements (DEFAULT)
  ina219.setMeasureMode(CONTINUOUS); // choose mode and uncomment for change of default
  /* Set PGain
  * Gain *  * Shunt Voltage Range *   * Max Current (if shunt is 0.1 ohms) *
   PG_40       40 mV                    0.4 A
   PG_80       80 mV                    0.8 A
   PG_160      160 mV                   1.6 A
   PG_320      320 mV                   3.2 A (DEFAULT)
  ina219.setPGain(PG_320); // choose gain and uncomment for change of default
  /* Set Bus Voltage Range
   BRNG_16   -> 16 V
   BRNG_32   -> 32 V (DEFAULT)
  ina219.setBusRange(BRNG_16); // choose range and uncomment for change of default
  Serial.println("INA219 Current Sensor Example Sketch - Continuous");
  /* If the current values delivered by the INA219 differ by a constant factor
     from values obtained with calibrated equipment you can define a correction factor.
     Correction factor = current delivered from calibrated equipment / current delivered by INA219
  // ina219.setCorrectionFactor(0.98); // insert your correction factor if necessary
  /* If you experience a shunt voltage offset, that means you detect a shunt voltage which is not
     zero, although the current should be zero, you can apply a correction. For this, uncomment the
     following function and apply the offset you have detected.
  //ina219.setShuntVoltOffset_mV(0.5); // insert the shunt voltage (millivolts) you detect at zero current
  double shuntVoltage_mV = 0.0;
  double loadVoltage_V = 0.0;
  float busVoltage_V = 0.0;
  float current_mA = 0.0;
  float power_mW = 0.0;
  bool ina219_overflow = false;
  shuntVoltage_mV = ina219.getShuntVoltage_mV();
  busVoltage_V = ina219.getBusVoltage_V();
  current_mA = ina219.getCurrent_mA();
  power_mW = ina219.getBusPower();
  loadVoltage_V  = busVoltage_V + (shuntVoltage_mV/1000);
  ina219_overflow = ina219.getOverflow();
  Serial.print("Shunt Voltage [mV]: "); Serial.println(shuntVoltage_mV);
  Serial.print("Bus Voltage [V]: "); Serial.println(busVoltage_V);
  Serial.print("Load Voltage [V]: "); Serial.println(loadVoltage_V);
  Serial.print("Current[mA]: "); Serial.println(current_mA);
  Serial.print("Bus Power [mW]: "); Serial.println(power_mW);
  if(!ina219_overflow){
    Serial.println("Values OK - no overflow");
  else{
    Serial.println("Overflow! Choose higher PGAIN");
  delay(10000);
Try this
I2C_ADDRESS 0x40
Or run an I2C scanner Sketch which will tell you the address of working devices on the I2C bus.
it still the same. :smiling_face_with_tear: thank you! :grinning:
The Serial Monitor is displaying this. :open_mouth:
ζˆͺεœ– 2023-11-19 ε‡Œζ™¨1.31.16
Then either the wiring is faulty, the INA219 board is faulty or its the ESP32.
I ran up a INA219 board on an ESP32S3 recently, the first program I used was the I2C scanner, and that did detect the INA219 board.
The board worked too, for reading a battery voltage.
Are you using a Nano esp32?? Cause the i2c terminals are on A4 & A5 or gpio 11 & 12 …
just a thought…
i'm using esp32-s.
ok,I will try that.thank you! :grin:
When I connect only the SCL to pin 22, many addresses appear, as shown in the image. Sometimes it says 'no found', and sometimes there are one or two addresses... This doesn't sound quite normal. Moreover, when I also connect the SDA to pin 21, it keeps saying 'no found'.
You can check the IΒ²C interface with an Arduino UNO or similar.
I've been testing I2C with an Arduino, but there's no response, and it just keeps displaying 'Scanning...'
"I used the sample code 'getCurrent', along with following the steps in this YouTube video, but it only outputs 'Hello!'
YouTube:https://www.youtube.com/watch?v=WI4pWs0DYPU&t=208s
my Arduino serial:
code:
#include <Wire.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
void setup(void)
  while (!Serial) {
      // will pause Zero, Leonardo, etc until serial console opens
      delay(1);
  Serial.println("Hello!");
  // Initialize the INA219.
  // By default the initialization will use the largest range (32V, 2A).  However
  // you can call a setCalibration function to change this range (see comments).
  if (! ina219.begin()) {
    Serial.println("Failed to find INA219 chip");
    while (1) { delay(10); }
  // To use a slightly lower 32V, 1A range (higher precision on amps):
  //ina219.setCalibration_32V_1A();
  // Or to use a lower 16V, 400mA range (higher precision on volts and amps):
  //ina219.setCalibration_16V_400mA();
  Serial.println("Measuring voltage and current with INA219 ...");
void loop(void)
  float shuntvoltage = 0;
  float busvoltage = 0;
  float current_mA = 0;
  float loadvoltage = 0;
  float power_mW = 0;
  shuntvoltage = ina219.getShuntVoltage_mV();
  busvoltage = ina219.getBusVoltage_V();
  power_mW = ina219.getPower_mW();
  loadvoltage = busvoltage + (shuntvoltage / 1000);
  Serial.print("Bus Voltage:   "); Serial.print(busvoltage); Serial.println(" V");
  Serial.print("Shunt Voltage: "); Serial.print(shuntvoltage); Serial.println(" mV");
  Serial.print("Load Voltage:  "); Serial.print(loadvoltage); Serial.println(" V");
  Serial.print("Current:       "); Serial.print(current_mA); Serial.println(" mA");
  Serial.print("Power:         "); Serial.print(power_mW); Serial.println(" mW");
  Serial.println("");
  delay(2000);
I moved your topic to a more appropriate forum category @didi1225.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
Go back to basics.
If the I2C scanner does not detect the board, then the applications are not going to work.
Which INA219 board (weblink).
Boards with VCC markings usually don't have a voltage regulator,
which means you must power VCC from the logic voltage of the MCU.
3.3volt in this case, not 5volt.
That won't solve the problem, but it stops pulling up the ESP pins to 5volt.
Leo..
I replaced both the ESP32 and the INA219, but the situation remains the same. I supplied 3.3V to the INA219, and provided 4.7K pull-up resistors for both the SCL and SDA lines.
thanks.
update
Remove the 4.7K resistors.
