Hi. Please help me understand on how to make a data structure with Millis() that will be sent to the receiver( ESPNOW SLAVE1) to switch on and off the led.
Im Using Esp32 Wroom-DA module( ESPNOW One way to Many ).
I attach a copy below.
Any help appreciated. Thanks.
// ESPNOW MASTER
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR ESP RECEIVER'S MAC ADDRESS
uint8_t broadcastAddress1[] = {0xEC, 0x62, 0x60, 0x84, 0x31, 0x04};
uint8_t broadcastAddress2[] = {0xEC, 0x62, 0x60, 0x94, 0xBB, 0xD0};
uint8_t broadcastAddress3[] = {0xEC, 0x62, 0x60, 0x84, 0x31, 0x78};
typedef struct test_struct {
int x;
int y;
} test_struct;
test_struct test;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
char macStr[18];
Serial.print("Packet to: ");
// Copies the sender mac address to a string
snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
Serial.print(macStr);
Serial.print(" send status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
WiFi.mode(WIFI_STA);
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
return;
esp_now_register_send_cb(OnDataSent);
// register peer
peerInfo.channel = 0;
peerInfo.encrypt = false;
// register first peer
memcpy(peerInfo.peer_addr, broadcastAddress1, 6);
if (esp_now_add_peer(&peerInfo) != ESP_OK){
Serial.println("Failed to add peer");
return;
// register second peer
memcpy(peerInfo.peer_addr, broadcastAddress2, 6);
return;
/// register third peer
memcpy(peerInfo.peer_addr, broadcastAddress3, 6);
return;
test.x = random(0,20);
test.y = random(0,20);
esp_err_t result = esp_now_send(0, (uint8_t *) &test, sizeof(test_struct));
if (result == ESP_OK) {
Serial.println("Sent with success");
else {
Serial.println("Error sending the data");
delay(2000);
//ESPNOW SLAVE1
#include <WiFi.h>
//Structure example to receive data
//Must match the sender structure
int x;
int y;
} test_struct;
//Create a struct_message called myData
test_struct myData;
//callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Bytes received: ");
Serial.println(len);
Serial.print("x: ");
Serial.println(myData.x);
Serial.print("y: ");
Serial.println(myData.y);
//Initialize Serial Monitor
//Set device as a Wi-Fi Station
//Init ESP-NOW
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
