I am quite new to programming and I am trying to modify a guitar pedal code I found on the internet: I am trying to build in a potentiometer to change the bitrate or distortion. Does anyone have an idea how i could get this to work?
Thx for your help in advance.
Here is my code:
/defining the output PWM parameters
#define PWM_FREQ 0x00FF // pwm frequency - 31.3KHz
#define PWM_MODE 0 // Fast (1) or Phase Correct (0)
#define PWM_QTY 2 // 2 PWMs in parallel
//other variables
int input = 0; // input signal
unsigned int ADC_low, ADC_high;
// setup ADC
ADMUX = 0x60; // left adjust, adc0, internal vcc
ADCSRA = 0xe5; // turn on adc, ck/32, auto trigger
ADCSRB = 0x07; // t1 capture for trigger
DIDR0 = 0x01; // turn off digital inputs for adc0
// setup PWM
TCCR1A = (((PWM_QTY - 1) << 5) | 0x80 | (PWM_MODE << 1)); //
TCCR1B = ((PWM_MODE << 3) | 0x11); // ck/1
TIMSK1 = 0x20; // interrupt on capture interrupt
ICR1H = (PWM_FREQ >> 8);
ICR1L = (PWM_FREQ & 0xff);
DDRB |= ((PWM_QTY << 1) | 0x02); // turn on outputs
// turn on interrupts - not really necessary with arduino
void getADCdata()
// get ADC data
ADC_low = ADCL; // you need to fetch the low byte first
ADC_high = ADCH;
//construct the input sumple summing the ADC low and high byte.
input = ((ADC_high << 8) | ADC_low) + 0x8000; // make a signed 16b value
void writePWMdata()
OCR1AL = ((input + 0x8000) >> 8); // convert to unsigned, send out high byte
OCR1BL = input; // send out low byte
ISR(TIMER1_CAPT_vect)
getADCdata();
writePWMdata();
