Hi all,
I am struggling with a issue here, I made a LCD controller that lets you control a LCD by i2c,
The page is here: http://freeduality.tk/?page_id=16
the library for the project: GitHub - Duality4Y/IOlcd: lcd controled through a IOexpander (MCP23016)
However i noticed that the Lcd doesn't always initialize, I fixed this by putting a delay(200); before lcd.init();
what lcd.init(); does is initialize the i2c connection, however i am trying to do this with a sketch:
the lcd won't initialize, not with the way explained here: http://web.alfredstate.edu/weimandn/lcd/lcd_initialization/lcd_initialization_index.html the way like in begin1(); in the sketch.
or the way i initialize it in the library (which is begin0()
the sketch is bare, it doesn't use the library.
I hope someone can help me solve the issue, things I have noticed that initialize the lcd is pressing the reset after a upload,
opening a Serial monitor.
The example from the library that works (with the delay(200); added);
//include the nesecary header files for this to work.
#include <IOlcd1_0.h>
#include <Wire.h>;
IOlcd1_0 lcd;
long count = 1;
void setup(){
//initialize the chip(in this case MCP23016) at address 0x20
delay(200);
lcd.init(0x20, MCP23016);
//start the lcd
lcd.begin(16,2);
//at the begining of the first line.
lcd.home();
//clear lcd just incase.
lcd.clear();
//print hello world to the first line.
lcd.print("Hello, World!");
void loop(){
//set cursor to the second line.
lcd.setCursor(0,1);
//number of seconds active, is printed.
lcd.print(count);
count++;
the code i am currently working on:
#include <Wire.h>;
#define address 0x20
#define Enable 64
#define RS 128
#define IODIR0 0x06
#define IODIR1 0x07
//a High is 1
#define allHigh 0xFF
//a low is 0
#define allLow 0x00
//input is 1
#define allInput 0xFF
//output is 0
#define allOutput 0x00
//Data buss port0
#define Port0 0x00
//Rs and E connected to Port1
#define Port1 0x01
void setup(){
pinMode(13, OUTPUT);
begin1();
for(int i=0;i<255;i++){
write(i);
void loop(){
//this is what i have in my IOlcd library.
void begin0(){
initChip();
delay(100);
//tell we are bitmode 8 and 2 lines
writeCommand(0x38);
//wait a bit
delayMicroseconds(4500);
//try second time
writeCommand(0x38);
delayMicroseconds(1500);
//third and last try
writeCommand(0x38);
//set display on and enter entry mode
writeCommand(0x0c);
writeCommand(0x06);
writeCommand(0x02);
delayMicroseconds(60);
//this is from here: http://web.alfredstate.edu/weimandn/lcd/lcd_initialization/lcd_initialization_index.html
void begin1(){
initChip();
delay(100);
writeCommand(0x30);
delay(5);
writeCommand(0x30);
delayMicroseconds(150);
writeCommand(0x30);
writeCommand(0x38);
writeCommand(0x08);
writeCommand(0x01);
delay(5);
writeCommand(0x06);
//turn the display on:
writeCommand(0x0C);
//this is a test init.
void initChip(){
Wire.begin();
sendData(IODIR0, allOutput);
sendData(IODIR1, allOutput);
int byteShift(int num){
int var = 0;
int i, x, y, p;
int s = 8;
for(i=0;i<(s/2);i++){
p = s-i-1;
x = num&(1<<p);
x = x >> p;
y = num & (1<<i);
y = y>>i;
var = var | (x<<i);
var = var | (y<<p);
return var;
//void writeCommand4bits(uint8_t _data){
//writeCommand(_data>>4);
//writeCommand(_data&0x08);
//void write4bits(uint8_t _data){
//write(_data>>4);
//write(_data&0x08);
void writeCommand(uint8_t _data){
_data = byteShift(_data);
sendData(Port0, _data);
sendData(Port1, Enable);
sendData(Port1, 0x00);
void write(uint8_t _data){
sendData(Port1, RS | Enable);
sendData(Port1, RS);
boolean sendData(uint8_t port, uint8_t _data){
Wire.beginTransmission(address);
Wire.write(port);
Wire.write(_data);
Wire.endTransmission();
Greetings Duality.
Thanks!
