Problem integrating Ultrasonic sensor HC-SRO4 Add-on Library for Arduino
Hello,
I'm trying to add a Library for Ultrasonic Sensor HC-SR04 for Arduino. I have followed the instructions given in link below, but still no luck.
Regards
Hassee.
 * HC-SR04 Demo
 * Demonstration of the HC-SR04 Ultrasonic Sensor
 * Date: August 3, 2016
 * Description:
 *  Connect the ultrasonic sensor to the Arduino as per the
 *  hardware connections below. Run the sketch and open a serial
 *  monitor. The distance read from the sensor will be displayed
 *  in centimeters and inches.
 * Hardware Connections:
 *  Arduino | HC-SR04
 *    5V    |   VCC
 *    7     |   Trig
 *    8     |   Echo
 *    GND   |   GND
 * License:
 *  Public Domain
// Pins
const int TRIG_PIN = 7;
const int ECHO_PIN = 8;
// Anything over 400 cm (23200 us pulse) is "out of range"
const unsigned int MAX_DIST = 23200;
  // The Trigger pin will tell the sensor to range find
  pinMode(TRIG_PIN, OUTPUT);
  digitalWrite(TRIG_PIN, LOW);
  // We'll use the serial monitor to view the sensor output
  unsigned long t1;
  unsigned long t2;
  unsigned long pulse_width;
  float cm;
  float inches;
  // Hold the trigger pin high for at least 10 us
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  // Wait for pulse on echo pin
  while ( digitalRead(ECHO_PIN) == 0 );
  // Measure how long the echo pin was held high (pulse width)
  // Note: the micros() counter will overflow after ~70 min
  t1 = micros();
  while ( digitalRead(ECHO_PIN) == 1);
  t2 = micros();
  pulse_width = t2 - t1;
  // Calculate distance in centimeters and inches. The constants
  // are found in the datasheet, and calculated from the assumed speed
  //of sound in air at sea level (~340 m/s).
  cm = pulse_width / 58.0;
  inches = pulse_width / 148.0;
  // Print out results
  if ( pulse_width > MAX_DIST ) {
    Serial.println("Out of range");
    Serial.print(cm);
    Serial.print(" cm \t");
    Serial.print(inches);
    Serial.println(" in");
  // Wait at least 60ms before next measurement
  delay(60);
