Problem interrupt pin change
Hello,
Sorry for my bad English, I'm French.
I want to intercept interrupts on pin A8 & A9 (arduino mega).
The following code give me :
Interrupt on pin A8 : 10 or 11 as result
Interrupt on pin A9 : 1 or 11 as result
I don't understand why results oscillate between 2 numbers ???
Thanks for helping.
Thierry
volatile byte pcint1_pins = B00000000;     // variable for current port K bits
volatile byte pcint1_pinsLast = B00000000; // variable for previous port K bits
volatile boolean print_flag1 = false;      // PCINT2 flag
  Serial.println("test interrupt change pin A8-A9");
  InitialiseIO();
  InitialiseInterrupt();
void InitialiseIO(){
  pinMode(A8, INPUT);	    // Pin A8 is input to which a switch is connected
  digitalWrite(A8, HIGH);   // Configure internal pull-up resistor
  pinMode(A9, INPUT);	    // Pin A9 is input to which a switch is connected
  digitalWrite(A9, HIGH);   // Configure internal pull-up resistor
void InitialiseInterrupt(){
  cli();		    // switch interrupts off while messing with their settings
  PCICR |= (1 << PCIE2);    // enable PCINT2
  PCMSK2 |= (1 << PCINT16); // mask for bit0 of port K (A8)
  PCMSK2 |= (1 << PCINT17); // mask for bit1 of port K (A9)
  sei();		    // turn interrupts back on
ISR(PCINT2_vect) {    // Interrupt service routine
  byte saveSREG = SREG;
  noInterrupts();
  pcint1_pins ^= ((PINK & B00000011) ^ (pcint1_pinsLast & B00000011));
  pcint1_pinsLast = pcint1_pins;
  print_flag1 = true;
  SREG = saveSREG;
  interrupts();
    if (print_flag1 == true) { // interrupt detection
    noInterrupts();
    byte pci1 = pcint1_pins;
    interrupts();
    Serial.print("PCINT1 = ");
    Serial.println(pci1, BIN);
  noInterrupts();
  print_flag1 = true;
  SREG = saveSREG;
  interrupts();
Interrupts are disabled during an ISR. They are enabled again then the ISR ends. You do not have to help the Arduino do that.
Ok, i delete noInterrupts() & interrupts()
Thanks
Thierry
tbbelg:
Those are binary to show both pins at once.
if ( result & 1 ) then A9 is pressed.
if ( result & 2 ) then A8 is pressed.
Can be both.
I know but for testing I use just one interrupt at a time.
Sensor connect to A8 & nothing to A9 : results give 10 or 11
Sensor connect to A9 & nothing to A8 : results gives 01 or 11
Thierry
The result gives status of both pins regardless of which triggered the interrupt.
The numbers you show are Binary. Binary 1 is Decimal 1 and Binary 10 is Decimal 2.
Nothing connected, if that is unterminated pin then what it reads "floats". The circuit needs to be connected or pulled up or down depending on the circuit or you need to change the IRQ to only read the connected pin.
Ok, I will try to connect 2 sensors for testing.
Also I configure internal pull-up resistor, so it doesn't care if something connec ou not. I'm wrong ?
Thanks.
Thierry
No that is right.
However because you did not post all your code there is no way we could have seen that.
I post all the code :
Here is what i use to configure internal pull-up resistor, is it correct ?
I was used to doing it that way before changing from IDE 0022 to IDE 1.03
As of Arduino 1.0.1, it is possible to enable the internal pullup resistors with the mode INPUT_PULLUP.
Additionally, the INPUT mode explicitly disables the internal pullups.
I think that the digitalWrite to HIGH enables those pullups.
With pullup enabled the pin will read LOW on a button press to ground, opposite to 5V to button to INPUT pin.
I tried to change to INPUT_PULLUP but results are the same
Looks dodgy to me - what are you expecting these lines to do?
To know what pin triggered the interrupt.
But if another solution exist let me know because i didn't find
You do know that ^ is an EXCLUSIVE OR
I can't follow that either.
Do you know how to determine the pin that's triggered ?
Quick answer is to keep track of what has been triggered and work with the change.
If it is a human finger on a button making the change then just the touch will take a very long time in Arduino cycles.
But the button itself will present another problem if it is not hardware debounced. The contact is not clean. Arduino with good code will see maybe dozens or more press and release events (the bounce) for every touch. The interrupt will catch them all, for all the good it will do.
If it is not a human and/or button but rather something very fast or fleeting, interrupt is justified. But for humans and sloppy inputs the first question I think is "why?".
Yes it is 2 TSL235R connected to pin 8 & 9.
So interrupt needed.
Thierry
Code execution will be more interesting then, just because of the speed/timing.
I am pretty sure that Pin Change interrupts all use 1 IRQ. And this example is pretty good.
If you save the previous read then you can XOR that with the current read in the IRQ, result will be the change.
Note that it will be possible for both pins to change in the same short time it takes to read, but unlikely.
I don't figure out how to do that :frowning:
