Hi all,
I am trying to understand the PIN change interrupt in Arduino UNO. I am using Proteus for simulating the UNO. Even after goign throught the datasheet and various forums and demo codes, i can not see whats the mistake that I am making in this code. The simple code that I wrote toggles a variable and displays as an LEd output. I also, attached another LED to see if the PIN is reading properly. I can see the Button is pressing and reading in the main loop, but it seems that the ISR is not processing. If anyone could have a look at the code and please guide if there are any mistakes in the code.
I like interrupts and so I'm interested in the discussion. Coding Badly your answer is vague but is it because of the bitwise NOT ~ causing the problem instead of using boolean NOT !
toggle= ~digitalRead(7);
toggle= !digitalRead(7);
Hi all,
Thank you for the replies.
I tried to implement the change, but the result is the same the ISR is not running. I changed the code slightly, and its simpler now. Just blinks the LED connected to A0 if the ISR running.
I am attaching the proteus project that I have for members reference.
Also, if anyone has a working code snippet of the interrupt on change, please share it with me so that it can be a reference to me.
As for testing interrupts
Have you tried the function attachInterrupt?
You will need to change to pin 2 for your interrupt pin for this to work.
Example in the Arduino reference I changed the led pin to A0
Yes, I hav etried the attache interrput function. And I think that wouldnot serve my purpose. I would like to connect 4 buttons to the arduino, and would like them to be read with the interrupt. I wouldnot want to polle for the switches.
Also, in real code I will not be using the delay in the ISR, the delay in that was just kept to see if the ISR is functional.
So could anyone see what I am missing to enable the interrput on change
I would like to learn how the pin change interrupt works. And like to implement it. I have tried and implemented the polling methode for the button reading. And also, as the projects get bigger, I believe button read from the interrupt is more easier to code.
In the interrupt handler, you read the state of the switch, and set a flag. In loop(), you check the state of the flag and take some action.
Or, in loop(), you read the state of the switch and take some action.
I can't see that an interrupt is easier. YMMV.
Forget that crap. Ditch the simulator; go straight for the real thing.
Aside from all that, there have been problems pointed out in the code that you have posted. Have you corrected those? What does your code look like now? What does it do? How does that differ from what you want?
hi everyone,
I got my Mega today and I tried in that as well, but the PIN Change interrupt is not woring. I have searched and analyzed various codes, and I cant see why the interrupt is not working without using any library function. can any moderators shead light on this please. Also, again requesting if anyone has a working code for the PIN change interrupt, please share.....
Some comments regarding what you think this code is doing are definitely in order.
Not all pins on the Mega support pin change interrupts. You need to confirm that the pins you are trying to use do indeed support pin change interrupts.
OK, I have changed the vector name to detect PCINT on PIN22 on AtMega560. But the result is still the same!!!!
Does anyone worked on PCINT pls input their comments.
volatile int ISR_flag=0;
#define ISR_LED 13
#define Button 22
// the setup function runs once when you press reset or power the board
cli(); // Clearing any interrupt flags
PCICR |= 0b00000100; // PCIE2=1, enabling PCINT23:16
PCIFR |= 0b00000100; // PCIF2=0, Clearing the PCIF2 flag
// the above line is not as per the manual, as it says write logical 1 to it to clear the flag
PCMSK2|= 0b01000000; // PCINT22, Enabling the PCINT on Pin 22
PCMSK1|=1; // Disabling PCINT 15:8
PCMSK0|=1; // Disabling PCINT 0:7
sei();
pinMode(13, OUTPUT);
pinMode(Button,INPUT);
//digitalWrite(Button,HIGH);// Used a physical pullup resistor on the Pin 22
ISR(PCINT2_vect)
ISR_flag=1;
Serial.println("From ISR");
// the loop function runs over and over again forever
if(ISR_flag==1) //if ISR is enables the blinking is enabled
digitalWrite(ISR_LED,HIGH);
digitalWrite(ISR_LED,LOW);
ISR_flag=0;
Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
