PROBLEM: Mysql + arduino + dth11
Hi
I have a big problem with passing data captured by the DTH11 (temperature) sensor to mysql
when it connects the arduino board it is all normal, it says: Connected but in the database there is no data. please if you could guide me with this. Thanks a lot
ARDUINO.ino
#include <dht.h>
#include <Ethernet.h>
#include <SPI.h>
// INTERNET EN LA TARJETA DE RED
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server (192, 168, 1, 4);
IPAddress subnet (255, 255, 255, 0);
IPAddress gateway (0, 0, 0, 0);
IPAddress ip (192, 168 , 1, 30);
EthernetClient client;
//#define dht_apin A0 // Analog Pin sensor is connected to
dht DHT;
float temperatura;
int analog_pin = A0;
//Configuracion de Arduino
while (!Serial)
//Inicializa el dispositivo de Ethernet
Ethernet.begin(mac, ip);
DHT.read11(analog_pin);
temperatura = DHT.temperature;
Serial.print(temperatura);
Serial.println(" °C");
Serial.println("Connecting...");
if (client.connect(server, 80)>0) {
 Serial.println("Connected");
 client.print(" GET /Ethernet.php?=temp=");
 client.print(temperatura);
 client.println(" HTTP/1.1");
 client.println("Host: ");
 client.println("Connection: close");
 client.println();
 Serial.println("Conectado");
 Serial.println("Fallo en la conexion");
if (!client.connected()) {
 Serial.println("Desconectado!");
 client.stop();
ETHERNET.php
<?php
$temp = $GET["temp"];
$enlace = mysqli_connect('localhost','root','','conexion')
or die ('No se puede conectar: ' .mysql_error());
echo 'Conexion exitosa
echo 'Se ingresaron los datos
echo '
echo 'Dato:           '.$temp;
echo '
$consulta = mysql_query($enlace, "INSERT INTO temperatura (temp) VALUES ($temp)");
if (!$consulta)
   echo "Error al guardar
   echo "Datos guardados
echo '
thank you very much :slight_smile:
Lee las normas y edita tu post usando etiquetas de código.
Lo mismo para el código en php.
it´s ok..
please help me...thanks
Your http string is:
 GET /Ethernet.php?=temp=temperatura HTTP/1.1
 Host:
 Connection: close
the '=' after '?' take it off.
No host, no connection.
Y no sé por qué hablo inglés en el foro de español....
