I believe I have the same module as
the guy http://woodsgood.ca/projects/2015/04/14/192x64-pixel-graphics-lcd-module/
The vendor sent me the same datasheet.
Don't know what is causing the failures?
Serial initialized
Reported Arduino Revision: 1.0.6
F_CPU: 16000000
Lib Configuration: openGLCD ver: 1.0rc2 build: v1.0rc2
Panel Configuration:ks0108-HJ19264A
Pin Configuration:ks0108-Uno
GLCD:ks0108 DisplayWidth:192 DisplayHeight:64
Chips:3 ChipWidth:64 ChipHeight:64
CSEL1:A0(PIN_C0) CSEL2:A1(PIN_C1) CSEL3:3(PIN_D3)
RW:A2(PIN_C2) DI:A3(PIN_C3) EN:2(PIN_D2)
D0:8(PIN_B0) D1:9(PIN_B1) D2:10(PIN_B2) D3:11(PIN_B3)
D4:4(PIN_D4) D5:5(PIN_D5) D6:6(PIN_D6) D7:7(PIN_D7)
Delays: tDDR:320 tAS:140 tDSW:200 tWH:450 tWL:450
ChipSelects:
CHIP0:(A0,0x0, A1,0x1, 3,0x1)
CHIP1:(A0,0x1, A1,0x0, 3,0x1)
CHIP2:(A0,0x1, A1,0x1, 3,0x0)
Data mode:
d0-d3:nibble mode-Non-Atomic
d4-d7:nibble mode-Non-Atomic
Backlight: <Not configured>
Diag Loop: 1
Initializing openGLCD
Displaying Library version Screen
Turning display on/off
Displaying ChipSelect Screens
Walking 1s data test
Compare error: 0 != 2
TEST FAILED
Test Count: 0 PASSED 1 FAILED
F_CPU: 16000000
ChipSelects:
Data mode:
Diag Loop: 2
Wr/Rd Chip Select Test
Compare error: chip:2 1 != 2
Compare error: chip:2 41 != 2
TEST FAILED
Test Count: 0 PASSED 2 FAILED
F_CPU: 16000000
ChipSelects:
Data mode:
Diag Loop: 3
Compare error: 0 != 8
Compare error: 0 != 20
TEST FAILED
Test Count: 0 PASSED 3 FAILED
