Problem Reading Data From Cloud (Thingspeak)
Hi, I am using this code to retrieve data from a Thingspeak channel in a JSON format. I am using an ESP8266 along with an Arduino Nano 33 BLE. The Nono 33 BLE Arduino board is not compatible with Thingspeak library and it doesn't support SoftwareSerial. Alternatively, I am using serial1 to communicate with the ESP8266 and REST API method to get the data from Thingspeak as it is shown in the code. However, I cannot get it to work. It is worth noting that Serial1.available() always gives zero even after adding delays.
I have used the same code to send data to the same Thingspeak channel and it works perfectly. I have no clue why it is not reading from the channel. I would really appreciate any help with this problem
Thanks in advance.
String AP ="xxxxxxxxxxx";
String PASS ="xxxxxxxxxxxxxx";
String PORT = "80";
String field = "Id";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
String Data ="";
  Serial1.begin(115200);
  sendCommand("AT",5,"OK",false);
  Serial1.println("AT+UART_DEF=9600,8,1,0,0");
  Serial1.end();
  Serial1.begin(9600);
  ConnectToWifi();
String getData="GET https://api.thingspeak.com/channels/1335558/fields/1?api_key=7XFZKXEGOV5HY4TQ";
 sendCommand("AT+CIPMUX=1",5,"OK",false);
 sendCommand("AT+CIPSTART=4,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK",false);
 sendCommand("AT+CIPSEND=4," +String(getData.length()+4),4,">",false);
 sendCommand(getData,20,"OK",true);
 delay(1500);
 countTrueCommand++;
 sendCommand("AT+CIPCLOSE=0",5,"OK",false);
bool ConnectToWifi(){
  for (int a=0; a<15; a++)
    sendCommand("AT+CWMODE=1",5,"OK",false);
    boolean isConnected = sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK",false);
    if(isConnected)
      return true;
bool sendCommand(String command, int maxTime, char readReplay[],boolean isGetData) {
  boolean result=false;
  //Test Purpose
  Serial.print(countTrueCommand);
  Serial.print(". at command => ");
  Serial.print(command);
  Serial.print(" ");
  while(countTimeCommand < (maxTime*1))
    Serial1.println(command);
    if(Serial1.find(readReplay))//ok
      if(isGetData)
          Serial.println("Success : Request is taken from the server");
         while(Serial1.available())
            char character = Serial1.read()
            Data.concat(character); /
            if (character == '\n')
             Serial.print("Received: ");
             Serial.println(Data);
             delay(50);
             Data = "";
      result = true;
    countTimeCommand++;
  if(result == true)
    Serial.println("Success");
    countTrueCommand++;
    countTimeCommand = 0;
  if(result == false)
    Serial.println("Fail");
    countTrueCommand = 0;
  found = false;
  return result;
