Problem send message with mkrwan1310 to TTN
Hey,
I manage to establish a connection between the MKRWAN1310 and the LORA network as you can see above. You can see this below :
2024-05-08 15_42_33-Clipboard
But when I want to send data, I get an error and this is what is displayed :
Here is a summary of my configuration
MRKWAN1310 which I updated to firmware version 1.3.0.0
I work with the MKRWAN_2 library
Here is my code
  Lora Send And Receive
  This sketch demonstrates how to send and receive data with the MKR WAN 1300/1310 LoRa module.
  This example code is in the public domain.
#include <MKRWAN_v2.h>
LoRaModem modem;
// Uncomment if using the Murata chip as a module
// LoRaModem modem(Serial1);
#include "arduino_secrets.h"
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
String appEui = SECRET_APP_EUI;
String appKey = SECRET_APP_KEY;
  while (!Serial);
  // change this to your regional band (eg. US915, AS923, ...)
  if (!modem.begin(EU868)) {
    Serial.println("Failed to start module");
    while (1) {}
  Serial.print("Your module version is: ");
  Serial.println(modem.version());
  Serial.print("Your device EUI is: ");
  Serial.println(modem.deviceEUI());
  int connected = modem.joinOTAA(appEui, appKey);
  if (!connected) {
    Serial.println("Something went wrong; are you indoor? Move near a window and retry");
    while (1) {}
  // Set poll interval to 60 secs.
  modem.minPollInterval(60);
  // NOTE: independently by this setting the modem will
  // not allow to send more than one message every 2 minutes,
  // this is enforced by firmware and can not be changed.
  Serial.println("Enter a message to send to network");
  Serial.println("(make sure that end-of-line 'NL' is enabled)");
  while (!Serial.available());
  String msg = Serial.readStringUntil('\n');
  Serial.print("Sending: " + msg + " - ");
  for (unsigned int i = 0; i < msg.length(); i++) {
    Serial.print(msg[i] >> 4, HEX);
    Serial.print(msg[i] & 0xF, HEX);
    Serial.print(" ");
  int err;
  modem.beginPacket();
  modem.print(msg);
  err = modem.endPacket(true);
  if (err > 0) {
    Serial.println("Message sent correctly!");
    Serial.println("Error sending message :(");
    Serial.println("(you may send a limited amount of messages per minute, depending on the signal strength");
    Serial.println("it may vary from 1 message every couple of seconds to 1 message every minute)");
  if (!modem.available()) {
    Serial.println("No downlink message received at this time.");
    return;
  char rcv[64];
  int i = 0;
  while (modem.available()) {
    rcv[i++] = (char)modem.read();
  Serial.print("Received: ");
  for (unsigned int j = 0; j < i; j++) {
    Serial.print(rcv[j] >> 4, HEX);
    Serial.print(rcv[j] & 0xF, HEX);
    Serial.print(" ");
Here you will find the payload configuration
why this doesn't work ?
Do you need more data to answer my problem?
Thank
why post is deleted ?
