THANK YOU ALL - Uno Problem solved - Over the years a component must have failed or a component of trace became corroded or there's a cold solder joint. I was able to find 3 other Arduino Unos I had and they are working perfectly. First think I noticed was when I went to select the port, it showed the Uno was connected.
Still having an issue with the Mega. But it's looking like if I upload the same Blink sketch I get an error, but the sketch works as it should. (I'll deal with this later).
I was into Arduino about 9 years ago and had to step away. For the past 9 years the two computers with all of my sketches, an Uno and Mega that and the 2 USB cables sat untouched.
I'm getting back into Arduino and opened the box thinking I could pickup where I left off.
Neither computer has been connected to the Internet, so NO UPDATES.
I'm running IDE 1.8.12
When I try and upload a sketch that was working to I'm getting the following error
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x24
I'm getting this with both computer, both usb cables and the Uno and the Mega.
Tried swapping USB cables and Arduinos between the two computers.
I have tried another USB cable, and the USB cables I have work with other devices.
Verified I'm using the correct board and USB port in IDE.
And yes the USB ports are working fine. Tested with a keyboard and mouse.
But what's interesting.... Is if I move the Arduino USB cable to a different USB port, IDE sees it.
No USB errors in Windows Device Manager.
Tried updating the boot loader, but since I can communicate with the Arduinos, I can't.
There are no shields on either board.
Both Arduinos are still running the code I last uploaded nearly 10 years ago.
I have a new (3rd) computer, Windows 10 where I downloaded the current IDE, 2.3.8 and it won't communicate either. Tried another USB cable, didn't work either.
I've can't even load something as simple as the the Blink sketch.
In every attempt the code complies without errors.
I have even gone so far as to install the CH340 driver. Which makes no sense as the software was everything was working perfectly 9 years ago.
Any suggestions?
Thank you
