Well, I was wrong, this model is different from others with 2x20 pin header.
Check the comments about the pinout in this code.
More informations and examples you can find here.
*This program is a demo of clearing screen to display red,green,blue.
*This demo was made for LCD modules with 8bit or 16bit data port.
*This program don't need to rely on any libraries and Can run directly.
* File : simple_test_ST7796S.ino
* Hardware Environment: Arduino Mega2560
* Build Environment : Arduino
*Set the pins to the correct ones for your development shield or breakout board.
*This demo use the BREAKOUT BOARD only and use these 16 data lines to the LCD,
//pin usage as follow:
// CS CD WR RD RST D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 D10 D11 D12 D13 D14 D15
//Arduino Mega 40 38 39 43 41 37 36 35 34 33 32 31 30 22 23 24 25 26 27 28 29
// TP_IRQ MOSI MISO TP_CS EX_CLK
//Arduino Mega 44 51 50 53 52
//when using the BREAKOUT BOARD only and using these 8 data lines to the LCD,
//Arduino Mega 40 38 39 43 41 37 36 35 34 33 32 31 30 / / / / / / / /
*Remember to set the pins to suit your display module!
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, QD electronic SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
#define LCD_MODE 1 //1-8bit,0-16bit
#define LCD_RD 43
#define LCD_WR 39
#define LCD_RS 38
#define LCD_CS 40
#define LCD_REST 41
void Lcd_Writ_Bus(unsigned int d)
#if LCD_MODE
//PORTC = d >> 8;
PORTC = d;
#else
PORTA = d >> 8;
PORTC = d;
#endif
*(portOutputRegister(digitalPinToPort(LCD_WR))) &= ~digitalPinToBitMask(LCD_WR);
*(portOutputRegister(digitalPinToPort(LCD_WR)))|= digitalPinToBitMask(LCD_WR);
void Lcd_Write_Com(unsigned int VH)
*(portOutputRegister(digitalPinToPort(LCD_RS))) &= ~digitalPinToBitMask(LCD_RS);//LCD_RS=0;
Lcd_Writ_Bus(VH);
void Lcd_Write_Data(unsigned int VH)
*(portOutputRegister(digitalPinToPort(LCD_RS)))|= digitalPinToBitMask(LCD_RS);//LCD_RS=1;
Lcd_Writ_Bus(VH);
void Lcd_Write_Com_Data(unsigned int com,unsigned int dat)
Lcd_Write_Com(com);
Lcd_Write_Data(dat);
void Address_set(unsigned int x1,unsigned int y1,unsigned int x2,unsigned int y2)
Lcd_Write_Com(0x2a);
Lcd_Write_Data(x1>>8);
Lcd_Write_Data(x1);
Lcd_Write_Data(x2>>8);
Lcd_Write_Data(x2);
Lcd_Write_Com(0x2b);
Lcd_Write_Data(y1>>8);
Lcd_Write_Data(y1);
Lcd_Write_Data(y2>>8);
Lcd_Write_Data(y2);
Lcd_Write_Com(0x2c);
void Lcd_Init(void)
digitalWrite(LCD_REST,HIGH);
delay(5);
digitalWrite(LCD_REST,LOW);
delay(15);
delay(15);
digitalWrite(LCD_CS,HIGH);
digitalWrite(LCD_WR,HIGH);
digitalWrite(LCD_CS,LOW); //CS
Lcd_Write_Com(0xF0);
Lcd_Write_Data(0xC3);
Lcd_Write_Data(0x96);
Lcd_Write_Com(0x36);
Lcd_Write_Data(0x68);
Lcd_Write_Com(0x3A);
Lcd_Write_Data(0x05);
Lcd_Write_Com(0xB0);
Lcd_Write_Data(0x80);
Lcd_Write_Com(0xB6);
Lcd_Write_Data(0x20);
Lcd_Write_Data(0x02);
Lcd_Write_Com(0xB5);
Lcd_Write_Data(0x03);
Lcd_Write_Data(0x00);
Lcd_Write_Data(0x04);
Lcd_Write_Com(0xB1);
Lcd_Write_Data(0x10);
Lcd_Write_Com(0xB4);
Lcd_Write_Com(0xB7);
Lcd_Write_Data(0xC6);
Lcd_Write_Com(0xC5);
Lcd_Write_Data(0x24);
Lcd_Write_Com(0xE4);
Lcd_Write_Data(0x31);
Lcd_Write_Com(0xE8);
Lcd_Write_Data(0x40);
Lcd_Write_Data(0x8A);
Lcd_Write_Data(0x29);
Lcd_Write_Data(0x19);
Lcd_Write_Data(0xA5);
Lcd_Write_Data(0x33);
Lcd_Write_Com(0xC2);
Lcd_Write_Com(0xA7);
Lcd_Write_Com(0xE0);
Lcd_Write_Data(0xF0);
Lcd_Write_Data(0x09);
Lcd_Write_Data(0x13);
Lcd_Write_Data(0x12);
Lcd_Write_Data(0x2B);
Lcd_Write_Data(0x3C);
Lcd_Write_Data(0x44);
Lcd_Write_Data(0x4B);
Lcd_Write_Data(0x1B);
Lcd_Write_Data(0x18);
Lcd_Write_Data(0x17);
Lcd_Write_Data(0x1D);
Lcd_Write_Data(0x21);
Lcd_Write_Com(0XE1);
Lcd_Write_Data(0x0C);
Lcd_Write_Data(0x0D);
Lcd_Write_Data(0x27);
Lcd_Write_Data(0x3B);
Lcd_Write_Data(0x4D);
Lcd_Write_Data(0x0B);
Lcd_Write_Com(0X36);
Lcd_Write_Data(0x08);
Lcd_Write_Data(0x69);
Lcd_Write_Com(0X13);
Lcd_Write_Com(0X11);
Lcd_Write_Com(0X29);
void H_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
unsigned int i,j;
Lcd_Write_Com(0x02c); //write_memory_start
digitalWrite(LCD_RS,HIGH);
l=l+x;
Address_set(x,y,l,y);
j=l*2;
for(i=1;i<=j;i++)
Lcd_Write_Data(c);
void V_line(unsigned int x, unsigned int y, unsigned int l, unsigned int c)
unsigned int i,j;
l=l+y;
Address_set(x,y,x,l);
j=l*2;
for(i=1;i<=j;i++)
Lcd_Write_Data(c);
void Rect(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
H_line(x , y , w, c);
H_line(x , y+h, w, c);
V_line(x , y , h, c);
V_line(x+w, y , h, c);
void Rectf(unsigned int x,unsigned int y,unsigned int w,unsigned int h,unsigned int c)
unsigned int i;
for(i=0;i<h;i++)
H_line(x , y+i, w, c);
int RGB(int r,int g,int b)
{return r << 16 | g << 8 | b;
void LCD_Clear(unsigned int j)
unsigned int i,m;
Address_set(0,0,320,480);
//Lcd_Write_Com(0x02c); //write_memory_start
//digitalWrite(LCD_RS,HIGH);
for(i=0;i<320;i++)
for(m=0;m<480;m++)
//Lcd_Write_Data(j>>8);
#if LCD_MODE
#endif
Lcd_Write_Data(j);
for(int p=0;p<10;p++)
pinMode(p,OUTPUT);
DDRA |= 0xFF;
DDRC |= 0xFF;
pinMode(38,OUTPUT);
pinMode(39,OUTPUT);
pinMode(40,OUTPUT);
pinMode(41,OUTPUT);
pinMode(43,OUTPUT);
digitalWrite(38, HIGH);
digitalWrite(39, HIGH);
digitalWrite(40, HIGH);
digitalWrite(41, HIGH);
digitalWrite(43, HIGH);
Lcd_Init();
//LCD_Clear(0xf800);
LCD_Clear(0xf800);
LCD_Clear(0x07E0);
LCD_Clear(0x001F);
for(int i=0;i<1000;i++)
Rect(random(300),random(300),random(300),random(300),random(65535)); // rectangle at x, y, with, hight, color
// LCD_Clear(0xf800);
