Problem trying to publish library
I am trying to publish a library which is an extension to an existing library that appears to have been abandoned.
My library has a different name to the original, but complains that there is an existing library of the same name.
Actual error:
Linting library in WiThrottleProtocol
ERROR: Library name WiThrottle is in use by a library in the Library Manager index. Each library must have a unique name
       value. If your library is already in the index, use the "--library-manager update" flag.
       See: https://arduino.github.io/arduino-cli/latest/library-specification/#libraryproperties-file-format
       (Rule LP017)
Is there any thing I can do to publish my version?
I suppose you cloned the other library to start and edited the .h and .cpp file
but have you changed the library.properties file to match your specifics? (like its name)
yes I have changed it.
the IDE does not seem to know.
have you updated your local copy?
yes, I made the changes on the local copy and pushed commited them.
There error is from the github pull request to the library-register, not the IDE.
actually have you looked at @pert comment one minute ago?
However, Library Manager works exclusively from Git tags, so the bot won't be able to see the fix you made until you create a new release or tag in the library repository.
Thanks.
I just saw it. I have 'hopefully' created the release now.
Peter
