And here a complete demo-code
#include <WiFi.h>
unsigned long MyTestTimer = 0; // variables MUST be of type unsigned long
const byte OnBoard_LED = 2;
const char *ssid = "";
const char *password = "";
// a lot of home-wlan-routers can be used as a NTP-server too
const char* ntpServer = "fritz.box";
const long gmtOffset_sec = 0;
const int daylightOffset_sec = 7200;
#include <time.h> // time() ctime()
time_t now; // this is the epoch
tm myTimeInfo; // the structure tm holds time information in a more convient way
void showTime() {
time(&now); // read the current time
localtime_r(&now, &myTimeInfo); // update the structure tm with the current time
Serial.print("year:");
Serial.print(myTimeInfo.tm_year + 1900); // years since 1900
Serial.print("\tmonth:");
Serial.print(myTimeInfo.tm_mon + 1); // January = 0 (!)
Serial.print("\tday:");
Serial.print(myTimeInfo.tm_mday); // day of month
Serial.print("\thour:");
Serial.print(myTimeInfo.tm_hour); // hours since midnight 0-23
Serial.print("\tmin:");
Serial.print(myTimeInfo.tm_min); // minutes after the hour 0-59
Serial.print("\tsec:");
Serial.print(myTimeInfo.tm_sec); // seconds after the minute 0-61*
Serial.print("\twday");
Serial.print(myTimeInfo.tm_wday); // days since Sunday 0-6
if (myTimeInfo.tm_isdst == 1) // Daylight Saving Time flag
Serial.print("\tDST");
Serial.print("\tstandard");
Serial.println();
void connectToWifi() {
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.persistent(false);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
BlinkHeartBeatLED(OnBoard_LED, 333);
delay(332);
Serial.print(".");
Serial.print("\n connected.");
Serial.println(WiFi.localIP() );
void synchroniseWith_NTP_Time() {
Serial.print("configTime uses ntpServer ");
Serial.println(ntpServer);
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
Serial.print("synchronising time");
while (myTimeInfo.tm_year + 1900 < 2000 ) {
BlinkHeartBeatLED(OnBoard_LED, 100);
delay(100);
Serial.print(".");
Serial.print("\n time synchronsized \n");
showTime();
void PrintFileNameDateTime() {
Serial.println( F("Code running comes from file ") );
Serial.println(__FILE__);
Serial.print( F(" compiled ") );
Serial.print(__DATE__);
Serial.print( F(" ") );
Serial.println(__TIME__);
boolean TimePeriodIsOver (unsigned long &periodStartTime, unsigned long TimePeriod) {
unsigned long currentMillis = millis();
if ( currentMillis - periodStartTime >= TimePeriod )
periodStartTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
Serial.println("\n Setup-Start \n");
PrintFileNameDateTime();
connectToWifi();
synchroniseWith_NTP_Time();
BlinkHeartBeatLED(OnBoard_LED,100);
if ( TimePeriodIsOver(MyTestTimer,1000) ) {
showTime();
best regards Stefan
