Hello,
I want to programm a midi controller with a touch sensor.
I can't get the touch sensor (adafruit mpr121) to work properly in my code.
Thus I added a few lines of code in the MPR121test sketch.
This is the sketch without my code:
Designed specifically to work with the MPR121 Breakout in the Adafruit shop
----> https://www.adafruit.com/products/
These sensors use I2C communicate, at least 2 pins are required
to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_MPR121.h"
// You can have up to 4 on one i2c bus but one is enough for testing!
Adafruit_MPR121 cap = Adafruit_MPR121();
// Keeps track of the last pins touched
// so we know when buttons are 'released'
uint16_t lasttouched = 0;
uint16_t currtouched = 0;
while (!Serial) { // needed to keep leonardo/micro from starting too fast!
delay(10);
Serial.println("Adafruit MPR121 Capacitive Touch sensor test");
// Default address is 0x5A, if tied to 3.3V its 0x5B
// If tied to SDA its 0x5C and if SCL then 0x5D
if (!cap.begin(0x5A)) {
Serial.println("MPR121 not found, check wiring?");
while (1);
Serial.println("MPR121 found!");
// Get the currently touched pads
currtouched = cap.touched();
for (uint8_t i=0; i<12; i++) {
// it if *is* touched and *wasnt* touched before, alert!
if ((currtouched & _BV(i)) && !(lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" touched");
// if it *was* touched and now *isnt*, alert!
if (!(currtouched & _BV(i)) && (lasttouched & _BV(i)) ) {
Serial.print(i); Serial.println(" released");
// reset our state
lasttouched = currtouched;
// comment out this line for detailed data from the sensor!
return;
// debugging info, what
Serial.print("\t\t\t\t\t\t\t\t\t\t\t\t\t 0x"); Serial.println(cap.touched(), HEX);
Serial.print("Filt: ");
Serial.print(cap.filteredData(i)); Serial.print("\t");
Serial.print("Base: ");
Serial.print(cap.baselineData(i)); Serial.print("\t");
// put a delay so it isn't overwhelming
delay(100);
Here it is with my code:
This is a library for the MPR121 12-channel Capacitive touch sensor
to interface
#include <Wire.h>
boolean zero = 0;
boolean four = 0;
boolean five = 0;
delay(10);
while (1);
if(i==0){zero = 1;}
if(i==4){four = 1;}
if(i==5){five = 1;}}
if (zero == 1){Serial.println("zero is touched");}
//if(four == 1 && zero == 1 && five ==1){Serial.println("one four five touched");}
if(i==0){zero = 0;}
if(i==4){four = 0;}
if(i==5){five = 0;}
// reset our state
return;
delay(100);
Now when I press the touch pin 0, it stops working (I don't get any text in the serial monitor, it says a couple times "zero is touched") then 0 is released and if I touch any pin I don't get any message in the serial monitor anymore".
Later I want to output a different midi note, depending on the combination of pins which are touched.
But it doesn't work with any code I write for this sensor.
Can anybody help me?
Thanks
