Problem when using DS3231 with an Arduino web server
Hello everyone. I've made a setup to log some data (power of a signal) and display it on a website. The code is as follows:
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include <Wire.h>
#include <Ard2499.h>
#include <stdio.h>
#include <DS3231.h>
#define FILE_NAME_LEN  30
#define HTTP_invalid   0
#define HTTP_GET       1
#define HTTP_POST      2
#define FT_HTML       0
#define FT_ICON       1
#define FT_CSS        2
#define FT_JAVASCRIPT 3
#define FT_JPG        4
#define FT_PNG        5
#define FT_GIF        6
#define FT_TEXT       7
#define FT_INVALID    8
#define PIN_ETH_SPI   10
File logDates;
char filename[30], path[15], currentDate[12], previousDate[12], temp[12], dateStr[12], timeStr[10];
int m, d, y, lastLine;
long log_time_ms = 500;
long prev_log_time = 0;
Ard2499 ard2499Board;
DS3231  rtc(SDA, SCL);
const byte mac[] PROGMEM = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
const byte ip[] = { 195, 130, 115, 124 };
const byte gateway[] PROGMEM = { 195, 130, 115, 200 };
const byte subnet[] PROGMEM = { 255, 255, 255, 0 };
EthernetServer server(80);
  pinMode(PIN_ETH_SPI, OUTPUT);
  digitalWrite(PIN_ETH_SPI, HIGH);
  Wire.begin();
  rtc.begin();
  ard2499Board.begin(ARD2499_ADC_ADDR_ZZZ, ARD2499_EEP_ADDR_ZZ);
  ard2499Board.ltc2499ChangeConfiguration(LTC2499_CONFIG2_SPEED_2X);
  ard2499Board.ltc2499ChangeChannel(LTC2499_CHAN_SINGLE_0P);
  if (!SD.begin(4)) {
    Serial.println("SD card intitialization failed");
  logDates = SD.open("logDates.txt", FILE_WRITE);
  logDates.close();
  Ethernet.begin((uint8_t*)mac, ip);
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.");
    while (true) {
      delay(1);
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("No cable");
  server.begin();
  Serial.print("IP:");
  Serial.println(Ethernet.localIP());
  if (client) {
    while (client.connected()) {
      if (ServiceClient(&client)) {
    delay(1);
    client.stop();
  LogData();
void LogData(void)
  unsigned long current_time;
  File logFile;
  current_time = millis();
  if ((current_time - prev_log_time) > log_time_ms) {
IF I COMMENT THE NEXT 3 LINES THEN THE SERVER WORKS
    m = rtc.getTime().mon;
    d = rtc.getTime().date;
    y = rtc.getTime().year;
    sprintf(path,"/%s/%d","LOGFILES",y);
    if (!SD.exists(path)) {
      SD.mkdir(path);
    sprintf(filename, "/%s/%d/%d-%d.txt","LOGFILES", y, m, d);
    prev_log_time = current_time;
    logFile = SD.open(filename, FILE_WRITE);
    if (logFile) {
      double adc = ard2499Board.ltc2499Read();
      double Vadc = (2.048/16777215.0)*adc;
      double P = -(Vadc-0.6447)/0.025;
      //write time
      logFile.print(rtc.getTimeStr());
      logFile.print("\t");
      //write power (dBm)
      logFile.println(P);
      logFile.close();
    logDates = SD.open("LOGDATES.txt", FILE_READ);
    sprintf(currentDate,"%02d/%02d/%d", m, d, y);
    lastLine = logDates.size()-12;
    if (lastLine < 0) {
      lastLine = 0;
    logDates.seek(lastLine);
    char temp[12];
    logDates.readStringUntil('\r').toCharArray(temp,12);
    strcpy(previousDate, temp);
    logDates.close();
    if (strcmp(currentDate, previousDate)!=0) {
      logDates = SD.open("LOGDATES.txt", FILE_WRITE);
      if (lastLine == 0) {
        logDates.println("MM/DD/YYYY");
        logDates.println("==========");
      logDates.println(currentDate);
      logDates.close();
bool ServiceClient(EthernetClient *client)
  static boolean currentLineIsBlank = true;
  char cl_char;
  File webFile;
  // file name from request including path + 1 of null terminator
  char file_name[FILE_NAME_LEN + 1] = {0};
  char http_req_type = 0;
  char req_file_type = FT_INVALID;
  const char *file_types[] = {"text/html", "image/x-icon", "text/css", "application/javascript", "image/jpeg", "image/png", "image/gif", "text/plain"};
  static char req_line_1[40] = {0};
  static unsigned char req_line_index = 0;
  static bool got_line_1 = false;
  if (client->available()) {
    cl_char = client->read();
    if ((req_line_index < 39) && (got_line_1 == false)) {
      if ((cl_char != '\r') && (cl_char != '\n')) {
        req_line_1[req_line_index] = cl_char;
        req_line_index++;
      else {
        got_line_1 = true;
        req_line_1[39] = 0;
    if ((cl_char == '\n') && currentLineIsBlank) {
      http_req_type = GetRequestedHttpResource(req_line_1, file_name, &req_file_type);
      if (http_req_type == HTTP_GET) {
        if (req_file_type < FT_INVALID) {
          webFile = SD.open(file_name);
          if (webFile) {
            // send a standard http response header
            client->println(F("HTTP/1.1 200 OK"));
            client->print(F("Content-Type: "));
            client->println(file_types[req_file_type]);
            client->println(F("Connection: close"));
            client->println();
            // send web page
            while(webFile.available()) {
              int num_bytes_read;
              char byte_buffer[64];
              // get bytes from requested file
              num_bytes_read = webFile.read(byte_buffer, 64);
              // send the file bytes to the client
              client->write(byte_buffer, num_bytes_read);
            webFile.close();
      req_line_1[0] = 0;
      req_line_index = 0;
      got_line_1 = false;
      return 1;
    if (cl_char == '\n') {
    else if (cl_char != '\r') {
      currentLineIsBlank = false;
  }  // if (client.available())
  return 0;
char GetRequestedHttpResource(char *req_line, char *file_name, char *file_type)
  char request_type = HTTP_invalid;
  char *str_token;
  *file_type = FT_INVALID;
  str_token =  strtok(req_line, " ");
  if (strcmp(str_token, "GET") == 0) {
    request_type = HTTP_GET;
    str_token =  strtok(NULL, " ");      // get the file name
    if (strcmp(str_token, "/") == 0) {
      strcpy(file_name, "index.htm");
      *file_type = FT_HTML;
    else if (strlen(str_token) <= FILE_NAME_LEN) {
      strcpy(file_name, str_token);
      // get the file extension
      str_token = strtok(str_token, ".");
      str_token = strtok(NULL, ".");
      if      (strcmp(str_token, "htm") == 0) {*file_type = 0;}
      else if (strcmp(str_token, "ico") == 0) {*file_type = 1;}
      else if (strcmp(str_token, "css") == 0) {*file_type = 2;}
      else if (strcmp(str_token, "js")  == 0) {*file_type = 3;}
      else if (strcmp(str_token, "jpg") == 0) {*file_type = 4;}
      else if (strcmp(str_token, "png") == 0) {*file_type = 5;}
      else if (strcmp(str_token, "gif") == 0) {*file_type = 6;}
      else if (strcmp(str_token, "txt") == 0) {*file_type = 7;}
      else {*file_type = 8;}
  else if (strcmp(str_token, "POST") == 0) {
    request_type = HTTP_POST;
  return request_type;
There is a function called "LogData()" that does all the logging. Everything used to work, but then i made a few small changes on the code. As a result i am no longer able to connect to the server. Considering that those changes were just some small tweaks, i didn't bother keeping a backup of the previous working state of the code. Sadly those changes were made about 2 months ago and i am having a hard time remembering exactly what they were. But i'm sure almost all of them were inside the LogData() function. I noticed that if i comment out 3 lines in that function (i mention them on the code), then the server works.Those 3 lines were exactly the same when the code worked. Can anyone help me out?
Libraries not included in the IDE:
PS. Sorry but i had to remove most comments to remain within the message character-limit.
