Problem when using two serial port in Arduino Uno.
I have a project by using Elechouse Voice recognition module V3 as a sound recognizer, after my command recognized by VoiceRecognizer V3, i want my bluetooth send some character to Android phone, everything run Okay but when i say send to my recognizer my bluetooth cant send character. Anyone can solve my problem ? I use SoftwareSerial .listen() to separate the working of two serial communication but didnt success,.
Maybe someone ever use this recognizer. I use sample program from this recognizer to modified. this is my program : my configuration pin include inside my program :
#include <SoftwareSerial.h>
#include "VoiceRecognitionV3.h"
 * Connection
 * Arduino    VoiceRecognitionModule
 * 10   ------->     TX
 * 9   ------->     RX
 *6   ------>  TX(HC-06)
 *5   ------>  RX(Voltage divider)
VR myVR(10,9);    // 10:RX 9:TX, you can choose your favourite pins.
SoftwareSerial myBT(6,5); //BT pin
uint8_t records[7]; // save record
uint8_t buf[64];
int led = 13;
String bt="HELP";
char inbyte;
#define kirimOn    (0)
#define ontesLED   (1)
#define offtesLED  (2)
  @brief   Print signature, if the character is invisible,
           print hexible value instead.
  @param   buf     --> command length
           len     --> number of parameters
void printSignature(uint8_t *buf, int len)
  int i;
  for(i=0; i<len; i++){
    if(buf[i]>0x19 && buf[i]<0x7F){
      Serial.write(buf[i]);
    else{
      Serial.print("[");
      Serial.print(buf[i], HEX);
      Serial.print("]");
  @param   buf  -->  VR module return value when voice is recognized.
             buf[0]  -->  Group mode(FF: None Group, 0x8n: User, 0x0n:System
             buf[1]  -->  number of record which is recognized.
             buf[2]  -->  Recognizer index(position) value of the recognized record.
             buf[3]  -->  Signature length
             buf[4]~buf[n] --> Signature
void printVR(uint8_t *buf)
  Serial.println("VR Index\tGroup\tRecordNum\tSignature");
  Serial.print(buf[2], DEC);
  Serial.print("\t\t");
  if(buf[0] == 0xFF){
    Serial.print("NONE");
  else if(buf[0]&0x80){
    Serial.print("UG ");
    Serial.print(buf[0]&(~0x80), DEC);
  else{
    Serial.print("SG ");
    Serial.print(buf[0], DEC);
  Serial.print("\t");
  Serial.print(buf[1], DEC);
  Serial.print("\t\t\n");
  if(buf[3]>0){
    printSignature(buf+4, buf[3]);
  else{
  Serial.println("\r\n");
  /** initialize */
  myVR.begin(9600);
  myBT.begin(9600);
  Serial.println("Elechouse Voice Recognition V3 Module\r\n send character to android");
  pinMode(led, OUTPUT);
  if(myVR.clear() == 0){
    Serial.println("Recognizer cleared.");
  }else{
    Serial.println("Not find VoiceRecognitionModule.");
    Serial.println("Please check connection and restart Arduino.");
    while(1);
  if(myVR.load((uint8_t)kirimOn) >= 0){
    Serial.println("kirim record loaded");
  if(myVR.load((uint8_t)ontesLED) >= 0){
    Serial.println("ontes loaded");
if(myVR.load((uint8_t)offtesLED) >= 0){
    Serial.println("offtes loaded");
  int ret;
  Serial.write(45);
  ret = myVR.recognize(buf, 50);
  if(ret>0){
    switch(buf[1]){
      case kirimOn:
        /** turn on LED /program lain untuk kontrol*/
        kirimchar();
      case ontesLED:
        /** turn on LED utk tes*/
        digitalWrite(led, HIGH);
      case offtesLED:
       /** tes led off*/
      digitalWrite(led, LOW);
      default:
        Serial.println("Record function undefined");
    /** voice recognized */
    printVR(buf);
    cekAndroid();
void cekAndroid(){
if (myBT.available() > 0)
    inbyte = myBT.read();
    if (inbyte == '0')
      //LED off
    else if (inbyte == '1')
      //LED on
void kirimchar(){
myBT.listen();
myBT.print(bt);
myBT.println();
delay(10);
No matter how manyinstances there are of SoftwareSerial only one of them can do one thing (listen or talk) at a time and it may be that your Voice library is conflicting with your other software serial port.
The obvious answer is to use a Mega with 4 Hardware Serial ports. Or a Leonardo which has two Hardware Serial connections, so would only need one Software Serial.
A third-best option would be to try my Yet another software serial for one of your connections.
...R
Ya i have downloaded your simpleSoftwareSerial, i place it ino the same directory with my file.ino , but i still confuse to try these extra class into my project. I will try again until my project can run and my bluetooth send its character to Android phone, is your new class sss possible to make conflict with this softwareSerial libarary?
thanks for your answer
ichbal_seb:
I don't think it should, but I never tried that. I wrote it to avoid a conflict with the Servo library and, mainly, so that people would have some code they could modify for their own purposes.
...R
Hi Friend,
Instead of software serial if you will use neoSwSerial it will work
What model Arduino are you using?
Thanks.. Tom.. :slight_smile:
This Thread was 3 years dead :slight_smile:
...R
