Good day!
I am trying to display a picture on a 0.95 inch 65k color OLED.
The only library I use is SPI.h and the only function I know is spi.transfer()
after the display initial part and use code below:
digitalWrite(DC,HIGH);// turn to data mode,
for (int x=0;x<12800;x++)
{int i=0xff;
SPI.transfer(i); // full screen white
it successfully turn the display full screen white.
however when when I change i=0x28(which should be red according to the driver datasheet), the oled displays some randomly colors
So what's the reason might cause this problem ? I totally stuck here for a long time.
and another question ,
may I possible just use SPI.transfer() to send the color picture bitmap to driver ram to display picture ?
I would like to know what's the source code to send the bitmap bit by bit to the driver ?
the bitmap is something like that(transfer by image2lcd):
/* const unsigned char gImage_16bit[2250] = {
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XDF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,.................}
thanks in advance!
SSD1331_1.0.pdf (780 KB)
