Problem with a code for a project!
Hey everyone I'm a beginner in Arduino and recently i'm doing a project trying to find magnetic field strength with a magneto resistive sensor (QMC5883L) but I think I got a problem because value of M its not correct ,its very high and keeps changing when I rotate my sensor, as I know it should be constant unless a magnet is near the sensor, can anyone help me realize what am I missing?
Any help would be appreciated!
This is the code:
#include <Wire.h> //I2C Arduino Library
#define addr 0x0D //I2C Address for The HMC5883
int minX = -3105;
int maxX = 6685;
int minZ = 0;
int maxZ = 16490;
int minY = -8955;
int maxY = 362;
double xx=0,zz=0,yy=0;
  Wire.begin();
  Wire.beginTransmission(addr); //start talking
  Wire.write(0x0B); // Tell the HMC5883 to Continuously Measure
  Wire.write(0x01); // Set the Register
  Wire.endTransmission();
  Wire.write(0x09); // Tell the HMC5883 to Continuously Measure
  Wire.write(0x1D); // Set the Register
  int x, y, z; //triple axis data
  //Tell the HMC what regist to begin writing data into
  Wire.write(0x00); //start with register 3.
  //Read the data.. 2 bytes for each axis.. 6 total bytes
  Wire.requestFrom(addr, 6);
  if (6 <= Wire.available()) {
    x = Wire.read(); //MSB  x
    x |= Wire.read() << 8; //LSB  x
    z = Wire.read(); //MSB  z
    z |= Wire.read() << 8; //LSB z
    y = Wire.read(); //MSB y
    y |= Wire.read() << 8; //LSB y
  int xoff=(minX+maxX)/2;
  int zoff=(minZ+maxZ)/2;
  int yoff=(minY+maxY)/2;
  float Xavg_delta=(maxX-minX)/2;
  float Zavg_delta=(maxZ-minZ)/2;
  float Yavg_delta=(maxY-minY)/2;
  int avg_delta=(Xavg_delta+Zavg_delta+Yavg_delta)/3;
  float Xscale=(avg_delta/Xavg_delta);
  float Zscale=(avg_delta/Zavg_delta);
  float Yscale=(avg_delta/Yavg_delta);
  float Xc=(x-xoff)*Xscale;
  float Zc=(z-zoff)*Zscale;
  float Yc=(y-yoff)*Yscale;
  float XXX=Xc/12000;
  float ZZZ=Zc/12000;
  float YYY=Yc/12000;
  float M=sqrt(XXX*XXX+ZZZ*ZZZ+YYY*YYY);
  Serial.print("X: ");
  Serial.print(Xc);
  Serial.print("Z: ");
  Serial.print(Zc);
  Serial.print("Y: ");
  Serial.print(Yc);
  Serial.print(" M: ");
  Serial.print(M);
  Serial.print("\n");
and this are values I get:
X: -12.12 Z: -9486.88 Y: 6161.23 M: 0.94
X: -21.81 Z: -9480.41 Y: 6184.15 M: 0.94
X: -9.69 Z: -9499.11 Y: 6308.96 M: 0.95
X: -39.9 Z: -9501.27 Y: 6241.46 M: 0.95
X: -1114.90 Z: -9662.43 Y: 5786.82 M: 0.94
X: -1617.82 Z: -9530.05 Y: 5714.23 M: 0.94
X: -306.60 Z: -9583.29 Y: 5900.16 M: 0.94
X: 448.38 Z: -9029.30 Y: 6296.22 M: 0.92
X: 427.78 Z: -9008.44 Y: 6167.60 M: 0.91
X: -135.73 Z: -8773.89 Y: 5369.11 M: 0.86
X: -671.36 Z: -8540.07 Y: 5283.78 M: 0.84
X: -539.27 Z: -8583.23 Y: 5286.33 M: 0.84
X: 8.48 Z: -9181.83 Y: 5566.50 M: 0.89
Isn't the earth magnetic? I think it has a north and south magnetic pole. Maybe you just have made a compass. :slight_smile:
aarg:
Yes my intention was to measure earth's intensity which in my country is 0.47gauss, but I'm getting higher number and it changes when I rotate,so what am I missing?
The program has calibration offset and scale constants for the magnetometer. Where did those come from?
What is the meaning of the scale factor 12000 in your program?
To calibrate the magnetometer on an absolute scale, you need to have a known reference magnetic field. It would be fine to use the 0.47 Gauss as the reference, if you believe that number.
Comprehensive tutorial on calibration.
jremington:
I had a code to find minimum and maximum from each axis and from those values I tried to find out the offsets and scaling factor.
Regarding "the scale factor 12000 in my program " I found it in a page while searching about QMC5883L that said:
"minimum gain: ±2G - 1/12000 = ±83.3uG/LSB : 0G ~ 2.73G"
To test whether that was done correctly, you rotate the sensor in space. If the corrected magnitude of the magnetic field vector changes, then you made a mistake.
The number 12000 is only an approximation to the correct absolute scale factor.
