Calibration of QMC5883L compass in low level programming
ive been working on a project which requires magnetometer and the coding im doing on it is low level. so, im facing an issue regarding its calibration as im rotating my qmc5883l chip im getting a heading between 22 degrees to 60 degrees something and the thing is like if i keep on rotating after these values for ex when it reaches 22 degrees and i keep rotating it actually starts increasing the angle linearly again like 23, 24....and so any fixes or a way to calibrate could be helpful
#include <Wire.h>
#define QMC5883_ADDRESS 0x0D
int16_t xread, yread, zread;
float xout, yout, zout;
  Wire.begin();
  // Control register 1: mode = continuous, output data rate = 10Hz, RNG = 8G, OSR = 512
  Wire.beginTransmission(QMC5883_ADDRESS);
  Wire.write(0x09);
  Wire.write(0b00010101); // OSR=512, RNG=8G, ODR=10Hz, continuous mode
  Wire.endTransmission();
  // Soft reset (optional)
  //Wire.beginTransmission(QMC5883_ADDRESS);
  //Wire.write(0x0A);
  //Wire.write(0x80);
  //Wire.endTransmission();
  // Set register pointer to data output
  Wire.write(0x00);
  Wire.requestFrom(QMC5883_ADDRESS, 6);
  if (Wire.available() == 6) {
    xread = Wire.read() | (Wire.read() << 8);
    yread = Wire.read() | (Wire.read() << 8);
    zread = Wire.read() | (Wire.read() << 8);
    xout = (float)xread / 30.0;
    yout = (float)yread / 30.0;
    zout = (float)zread / 30.0;
    float heading = atan2(yout, xout) * 180 / PI;
    if (heading < 0) heading += 360;
    //Serial.print("Xraw: "); Serial.print(xread);
    //Serial.print(" Yraw: "); Serial.print(yread);
    //Serial.print(" Zraw: "); Serial.print(zread);
    Serial.print("Xout: "); Serial.print(xout);
    Serial.print(" Yout: "); Serial.println(yout);
    Serial.print(" Heading: "); Serial.print(heading); Serial.println("°");
    Serial.println("Sensor not responding or insufficient data.");
The best general overview and tutorial on magnetometer calibration is
Magnetometer calibration is not "low level", though. If you are interested only in 2D (heading) measurements, 2D calibration is much simpler than 3D calibration.
