Problem with Adafruit DRV8833 and Arduino Nano rp2024
Hi there
I am using the DRV8833 with an Arduino Nano rp2040 to control two DC motors.
The wiring looks like this:
Vmotor - 9V
GND - ground
SLP - GPIO12
AIN1 - GPIO26
AIN2 - GPIO27
AIN1 - GPIO28
BIN2 - GPIO29
The code I am using is the following:
#define RIGHT_FORWARD 26
#define RIGHT_BACKWARD 27
#define LEFT_FORWARD 28
#define LEFT_BACKWARD 29
#define SLP 12
  Serial.println("Stepper test!");
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(RIGHT_FORWARD, OUTPUT);
  pinMode(RIGHT_BACKWARD, OUTPUT);
  pinMode(LEFT_FORWARD, OUTPUT);
  pinMode(LEFT_BACKWARD, OUTPUT);
  pinMode(SLP, OUTPUT);
  Serial.println("loop");
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(SLP, HIGH);
  digitalWrite(RIGHT_FORWARD, HIGH);
  digitalWrite(RIGHT_BACKWARD, LOW);
  digitalWrite(LED_BUILTIN, LOW);
  delay(200);
  digitalWrite(RIGHT_FORWARD, LOW);
  delay(200);
  delay(200);
The LED is blinking which indicates the program does run.
Also when I measure the GPIO26 I do get the expected 0 or 3.3v and on the GPIO12 I get the expected 3.3v.
But in the AOUT1 I would expect to see some voltage that goes to the DC motors, but there is nothing.
Does anyone have an idea why?
I did change the DRV (i have 4 of them, same problem with all of them) and I did change the Arduino, but nothing helps..
The battery might not have the power to drive two dc motors. Measure the battery voltage. Provide an accurate wiring drawing.
I am not sure what solved it but all of a sudden it works..
