Hello, I have been doing some prototyping with Arduino Nano. The goal is to read an analog voltage and if that reading is less than or equal to 2V I would like to turn on LED. I am reading the analog input from a power source that I am varying from 0-5V across a 1kOhm resistor. I was able to successfully do this when I power the Arduino from the USB 2.0 port. However, when I try to power it with a 5V regulated source, from a 12V to 5V Linear regulator(L7805), the readings are not correct as the LED powers on when the Analog input is less than or equal to 1V. I noticed that when I bypass the regulator and power with the 12V source all is well. I have attached some tinkerCad images of the when it is working via the USB Power. The only difference when it does not work is that I am powering the Arduino via the Vin and GND pins from the L7805 Vout and GND pins. I am using a 12V battery and an Arduino Nano but couldn't include that. Any help is appreciated.
int controlPin = 3;
int sensorPin = A2;
float sensorValue = 0.0;
float voltageValue;
//Serial.begin(9600);
pinMode(controlPin, OUTPUT);
pinMode(sensorPin, INPUT);
sensorValue = analogRead(sensorPin);
voltageValue = (5.0 / 1023.0) * sensorValue;
//Serial.println(voltageValue);
if (voltageValue < 2.0) {
digitalWrite(controlPin, 1);
else {
digitalWrite(controlPin, 0);
