Problem with Arduino Cloud IoT project
Continuing the discussion from [SOLVED] Couldn't use IoT Cloud more than once with Arduino UNO R4 WIFI:
i have same problem, help me
#include "arduino_secrets.h"
/* IoT based Solar Power Monitoring System with ESP32 over cloud
  Author: https://www.circuitschools.com */
#include "thingProperties.h"
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <BH1750.h>
// Define voltage sensor analog input
#define SIGNAL_PIN 27
float adc_voltage = 0.0;
float R1 = 30000.0;
float R2 = 7500.0;
float ref_voltage = 5;
int adc_value = 0;
//ACS712
const int sensorIn = 34;      // pin where the OUT pin from sensor is connected on Arduino
int mVperAmp = 185;           // this the 5A version of the ACS712 -use 100 for 20A Module and 66 for 30A Module
int Watt = 0;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//DS18B20
#define ONE_WIRE_BUS 15
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//BH1750
BH1750 lightMeter(0x23);
//LCD display
LiquidCrystal_I2C lcd (0x27, 16, 2);
  // Initialize serial and wait for port to open:
  // This delay gives the chance to wait for a Serial Monitor without blocking if none is found
  delay(1500);
  // Defined in thingProperties.h
  initProperties();
  // Connect to Arduino IoT Cloud
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  lcd. init ();
  lcd. backlight ();
  lcd. print ( "Solar monitor" );
  sensors.begin();//Dallas sensors
  Wire.begin(); //bh1750
  if (lightMeter.begin(BH1750::CONTINUOUS_HIGH_RES_MODE)) {
    Serial.println(F("BH1750 Advanced begin"));
  else {
    Serial.println(F("Error initialising BH1750"));
  delay(3000);
  lcd. clear();
  setDebugMessageLevel(2);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  //voltage sensor
  adc_value = analogRead(SIGNAL_PIN);
  adc_voltage  = (adc_value * ref_voltage) / 4096.0;
  in_voltage = adc_voltage / (R2 / (R1 + R2)) ;
  Serial.print("Input Voltage = ");
  Serial.print(in_voltage, 2);
  Serial.print(" V |");
  //acs712
  Voltage = getVPP();
  VRMS = (Voltage / 2.0) * 0.707; //root 2 is 0.707
  AmpsRMS = ((VRMS * 1000) / mVperAmp) - 0.3;
  Serial.print("Current = ");
  Serial.print(AmpsRMS, 2);
  Serial.print(" A |");
  //temp
  sensors.requestTemperatures();
  temp = sensors.getTempCByIndex(0);
  Serial.print("temperature = ");
  Serial.print(temp);
  Serial.print(" c |");
  //bh1750
  lux = lightMeter.readLightLevel();
  Serial.print("light = ");
  Serial.print(lux);
  Serial.println(" lx");
  //print on lcd
  lcd.setCursor (0, 0);
  lcd.print("V=");
  lcd.print(in_voltage, 2);
  lcd.print("v|");
  lcd.setCursor (8, 0);
  lcd.print("C=");
  lcd.print(AmpsRMS, 2);
  lcd.print("A");
  lcd.setCursor (0, 1);
  lcd.print("T=");
  lcd.print(temp, 1);
  lcd.print("c|");
  lcd.setCursor (8, 1);
  lcd.print("L=");
  lcd.print(lux);
float getVPP()
  float result;
  int readValue;                // value read from the sensor
  int maxValue = 0;             // store max value here
  int minValue = 4096;          // store min value here ESP32 ADC resolution
  uint32_t start_time = millis();
  while ((millis() - start_time) < 1000) //sample for 1 Sec
    readValue = analogRead(sensorIn);
    // see if you have a new maxValue
    if (readValue > maxValue)
      /*record the maximum sensor value*/
      maxValue = readValue;
    if (readValue < minValue)
      /*record the minimum sensor value*/
      minValue = readValue;
  // Subtract min from max
  result = ((maxValue - minValue) * 3.3) / 4096.0; //ESP32 ADC resolution 4096
  return result;
  Since Temp is READ_WRITE variable, onTempChange() is
  executed every time a new value is received from IoT Cloud.
void onTempChange()  {
  // Add your code here to act upon Temp change
