Problem with Arduino I2C and Ultrasonic sensor
Hi:
I am trying to have an ultrasonic rangefinder transfer it's distance readings from one Arduino to another via I2C. I've successfully established the I2C connection (I just sent over an integer variable that increments), and my ultrasonic rangefinder's values can be detected on serial of the Arduino that is controlling it. So, basically, I have the 2 individual parts working, and I need to integrate them.
Here is what my ultrasound slave's code looks like:
#include <Wire.h>
#define COMMANDPIN 2
  Wire.begin(2);                // join i2c bus with address #2
  Wire.onRequest(requestEvent); // register event
  pinMode(COMMANDPIN, OUTPUT);
  digitalWrite(COMMANDPIN, HIGH);
  delay(100);
void requestEvent()
  int index=0;
  while(index<100){
    Wire.send(ultrasoundread());// respond with message of 100 bytes
                       // as expected by master
int ultrasoundread()
   pinMode(COMMANDPIN, HIGH);
   pinMode(COMMANDPIN, LOW);
   delay(50);
   boolean startreading = false;
   char in[4];
   in[3] = 0;
   int index = 0;
   Serial.flush();
   while(index < 3){
     if(Serial.available()){
       byte incoming = Serial.read();
       if(incoming == 'R') startreading = true;
       else if(startreading) in[index++] = incoming;
   return atoi(in);
The master is:
#include <Wire.h>
  Wire.begin();        // join i2c bus (address optional for master)
  Serial.begin(9600);  // start serial for output
  Wire.requestFrom(2, 100);    // request 6 bytes from slave device #2
    int c = Wire.receive(); // receive a byte as character
    Serial.print((int)c);         // print the character
As you can see, the code for both programs is really straightforward, but I am not receiving any ultrasound readings on the master's serial connection.
My question is how do I dump 100 bytes of data onto the Wire in one shot?
I may be wrong but haven`t you got to use Wire.available() to see if there is any data there first .
What your code is saying to me is -
ask for 100 bytes
get 1 byte put into variable
ask for 100 bytes
I think there should be a loop to get all the 100 bytes from the buffer before asking for more.
