In file included from C:\Users\User\Documents\Arduino\libraries\IOXhop_FirebaseESP32-master/IOXhop_FirebaseESP32.h:8,
from D:\SEM 4\Mobile App\Firebase\Firebase.ino:2:
C:\Users\User\Documents\Arduino\libraries\IOXhop_FirebaseESP32-master/IOXhop_FirebaseStream.h:14:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see Redirecting… to learn how to upgrade your program to ArduinoJson version 6
StaticJsonBuffer<STREAM_JSON_BUFFER_SIZE> jsonBuffer;
C:\Users\User\Documents\Arduino\libraries\IOXhop_FirebaseESP32-master/IOXhop_FirebaseStream.h:65:11: error: StaticJsonBuffer is a class from ArduinoJson 5. Please see Redirecting… to learn how to upgrade your program to ArduinoJson version 6
return StaticJsonBuffer<STREAM_JSON_DATA_BUFFER_SIZE>().parseObject(_data);
I moved your topic to an appropriate forum category @latip.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Hi @latip. This error means you're using a version of the "ArduinoJson" library that is not compatible with this code. The ArduinoJson library 6.x.x versions have breaking changes that make them not work with code written for the ArduinoJson 5.x.x versions.
The recommended solution is to roll back to the newest 5.x.x release of ArduinoJson. I'll provide instructions you can follow to do that:
Select Sketch > Include Library > Manage Libraries... from the Arduino IDE menus to open the "Library Manager" view in the left side panel.
Type arduinojson in the "Filter your search..." field.
Scroll down through the list of libraries until you see the "ArduinoJson by Benoit Blanchon" entry.
You will see a drop-down version menu at the bottom of the entry. Select "5.13.5" from the menu.
Click the "INSTALL" button at the bottom of the entry.
Wait for the installation to finish.
Now try compiling or uploading your sketch again. The error should no longer occur.
The alternative solution is to update the code to work with the 6.x.x versions of the ArduinoJson library. You will find a guide to this here:
