Problem with AS5048A Rotary Encoder
Hi, I'm new to SPI and I thought a small project with AS5048A encoder would be a good introduction but so far no luck!
I got my hands on an AS5048A chip which I made a PCB for using the datasheet as a guide but so far I can't get a proper reading from the sensor. I'll post the schematics and the code so you'll better understand what I'm trying to do. I'm just trying to read the encoder position for a start.
I'm using Arduino Leonardo (so I can make a joystick) and using pins 13 for SCK, 12 for MISO, 11 for MOSI and 10 for CS. I also connected ground and power (I tried both 3v3 and 5 with no luck).
All I get from serial is this:
It makes no difference to the output whether the sensor is connected or not which drives me to the conclusion that it could be a fake chip.
Any help would be appreciated, thanks.
#include <SPI.h>
/*PINS
   Arduino SPI pins
   MOSI = 11, MISO = 12, SCK = 13, CS = 10
const byte CS_pin = 10; //Chip select pin for manual switching
uint16_t rawData = 0; //bits from the encoder (16 bits, but top 2 has to be discarded)
float degAngle = 0; //Angle in degrees
uint16_t command = 0b1111111111111111; //read command (0xFFF)
  SPI.begin();
  Serial.println("AS5048A - Magnetic position encoder");
  pinMode(CS_pin, OUTPUT); //CS pin - output
  SPI.beginTransaction(SPISettings(3000000, MSBFIRST, SPI_MODE1));
  //--sending the command
  digitalWrite(CS_pin, LOW);
  SPI.transfer16(command);
  digitalWrite(CS_pin, HIGH);
  delay(10);
  //--receiving the reading
  rawData = SPI.transfer16(command);
  SPI.endTransaction();
  rawData = rawData & 0b0011111111111111; //removing the top 2 bits (PAR and EF)
  degAngle = (float)rawData / 16384.0 * 360.0; //16384 = 2^14, 360 = 360 degrees
  Serial.print("Deg: ");
  Serial.println(degAngle);
Please post the entire schematic, including power sources.
If you applied 5V to a 3.3V chip, it is probably fried.
From the AS5048 data sheet:
I have two of these boards so I decided I cut the jumper between 3v3 and 5v on the sensor board so I can connect 5v to it using the Arduino provided 5v rail and that didn't make any difference. So I have two boards now with both configuration you posted and neither work.
are you using the right diametrically magnetized magnet and at the right distance? 0.5 to 2mm i think.
10 millisecond could be too long to delay, try 1 or 10 microseconds with microsecond delay function.
try lowering your SPISettings(3000000, ...) to 1000000
try to setup all your spi pins as input and output, miso(input) all the other output.
i just ordered some pcbs i designed with the as5048A too, hope they work they're the first pcbs i ever designed!
those are some things i saw on other people's code while doing research for those sensors
