Problem with BT module HC-05
I have a circuit where two pumps (currently just LED's) are activated by pressing two different buttons.
After its success, I updated the code to use a bluetooth module HC-05 and control it with an MIT App Inventor app.
Unfortunately, it doesn't work, and I don't know whether the problem lies in the Arduino or the app
The code goes as following:
//Constants pump 1 y 2
const int pin_pumpA = 2;
const int pin_pumpB = 3;
// BT state variable
int bt_state = 0;
pinMode (pin_pumpA, OUTPUT);
pinMode (pin_pumpB, OUTPUT);
//lectura del estado del texto BT
if (Serial.available() > 0)
bt_state = Serial.read();
if (bt_state == 1)
digitalWrite(pin_pumpA,HIGH);
delay(5000);
digitalWrite(pin_pumpA,LOW);
if (bt_state == 2)
digitalWrite(pin_pumpB,HIGH);
delay(5000);
digitalWrite(pin_pumpB,LOW);
I could use some help trying to find the problem, thanks!
If you use a different app than the MIT ap inventor to send a 1 or 2 does it work?
I have the "Serial Bluetooth Terminal" app I use for testing things like this. After you are connected you can simple commands and read simple feedback. Then you'll know if the problem is the app or the code.
Thank you, by using "Seria Bluetooth Terminal" I found out it was better to use a char variable instead of int.
Have a nice day
