Hello everyone!
I'm trying to integrate a LED Ring Game into my code, everything works perfectly if I only use the Led Ring Game code :
#include "FastLED.h"
#define NUM_LEDS 60
#define DATA_PIN A0
#define BRIGHTNESS 55
CRGB leds[NUM_LEDS];
CRGB sleds[NUM_LEDS];
bool reachedEnd = false;
byte gameState = 0;
//byte ledSpeed = 0;
int period = 1000;
unsigned long time_now = 0;
byte Position = 0;
byte level = 0;
const byte ledSpeed[6] = {50, 40, 30, 20, 14, 7};
//Debounce
bool findRandom = false;
byte spot = 0;
FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS);
pinMode(A3, INPUT_PULLUP);
Serial.println("Reset");
FastLED.setBrightness(BRIGHTNESS );
if (gameState == 0) {
fill_rainbow(leds, NUM_LEDS, 0, 20); //2 = longer gradient strip
if (digitalRead(A3) == LOW) {
Position = 0;
findRandom = true;
for (byte i = 0; i < NUM_LEDS; i++) {
leds[i].setRGB(0, 0, 0);
delay(40);
FastLED.show();
int thisPitch = map (i, 60, 0, 100, 1500);
tone(7, thisPitch,120);
gameState = 1;
FastLED.show();
if (gameState == 1) {
period = ledSpeed[0];
if (millis() > time_now + period) {
time_now = millis();
if (findRandom) {
spot = random(56) + 3;
findRandom = false;
leds[spot - 1].setRGB(255, 140, 0);
leds[spot].setRGB(0, 255, 0);
leds[spot + 1].setRGB(255, 110, 0);
sleds[0].setRGB(0, 255, 0);
PlayGame(spot - 1, spot + 1);
delay(300);
findRandom = false;
if (Position > spot - 1 && Position < spot + 3) {
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 2) {
// period = 320;
period = ledSpeed[1];
if (findRandom) {
findRandom = false;
leds[spot - 1].setRGB(255, 190, 0);
leds[spot + 1].setRGB(255, 190, 0);
sleds[1].setRGB(255, 255, 0);
delay(300);
if (spot - 1 && Position < spot + 3) {
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 3) {
period = ledSpeed[2];
if (findRandom) {
findRandom = false;
sleds[2].setRGB(255, 50, 0);
PlayGame(spot, spot);
delay(300);
if (Position == spot+1) {
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 4) {
period = ledSpeed[3];
if (findRandom) {
findRandom = false;
sleds[3].setRGB(255, 0, 0);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 5) {
period = ledSpeed[4];
if (findRandom) {
findRandom = false;
sleds[4].setRGB(0, 50, 255);
PlayGame(spot , spot);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 6) {
period = ledSpeed[5];
if (findRandom) {
findRandom = false;
sleds[5].setRGB(0, 150, 255);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (gameState == 98) {
winner();
if (gameState == 99) {
loser();
void PlayGame(byte bound1, byte bound2) {
leds[Position].setRGB(255, 0, 0);
if (Position < bound1 + 1 || Position > bound2 + 1) {
leds[Position - 1].setRGB(0, 0, 0);
FastLED.show();
Position++;
if (Position >= NUM_LEDS) {
Position = 0;
void winner() {
for (byte i = 0; i < 3; i++) {
for (byte j = 0; j < NUM_LEDS; j++) {
leds[j].setRGB(0, 255, 0);
tone(7, 1000, 250);
FastLED.show();
clearLEDS();
FastLED.show();
findRandom = true;
Position = 0;
gameState = level + 1;
if (gameState > 6) {
gameState = 0;
void loser() {
leds[j].setRGB(255, 0, 0);
tone(7, 200, 250);
FastLED.show();
clearLEDS();
FastLED.show();
gameState = 0;
void clearLEDS() {
void winAll(){
I've integrated it into my code which includes preliminary steps before launching the LED Ring Game, but when the Led Ring game is launched, the buzzer doesn't produce the expected sound and the button (pin A3) doesn't react to pressure. (The LED Ring does light up and the feedback in the console says it has launched).
I don't know why it doesn't work and I can't find a solution to make it work...
here's the complete final code:
#include <SPI.h>
#include <MFRC522.h>
// Prototypes de fonction
bool surveillerPins();
void playLEDGame();
void PlayGame(byte bound1, byte bound2);
void winner();
void loser();
void clearLEDS();
void winAll();
#define RST_PIN 5 // Configurable, voir ci-dessus
#define SS_PIN 53 // Configurable, voir votre configuration ci-dessus
MFRC522 mfrc522(SS_PIN, RST_PIN); // Créer une instance MFRC522
// Définition des pins et variables pour le jeu "LED ring"
#define NUM_LEDS 60
#define DATA_PIN A0
byte gameState = 0;
int period = 1000;
byte Position = 0;
byte level = 0;
// Débounce
byte spot = 0;
Serial.begin(9600); // Initier la communication série.
SPI.begin(); // Initier le bus SPI
mfrc522.PCD_Init(); // Initier le MFRC522
Serial.println("Présentez votre badge RFID pour le lire...");
FastLED.clear();
FastLED.show();
tone(7, 1000, 500);
bool buttonPressed = digitalRead(A3) == LOW;
// Vérifier si un nouveau badge RFID est présent et prêt à être lu
if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
delay(50);
return;
// Le badge est présent et prêt à être lu
// Afficher UID du badge
Serial.print("UID du badge:");
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
// Vérifier si l'UID du badge correspond à un UID autorisé
byte uidAutorise[] = {0xAC, 0x77, 0xEC, 0x21}; // Remplacez par l'UID de votre badge autorisé
bool autorise = true;
if (mfrc522.uid.uidByte[i] != uidAutorise[i]) {
autorise = false;
if (autorise) {
Serial.println("Badge autorisé!");
Serial.println("boitier elec");
if (surveillerPins()) { // Si surveillerPins retourne true
playLEDGame(buttonPressed);
Serial.println("Badge non autorisé.");
// Assurez-vous de stopper la lecture du badge actuel avant d'en lire un nouveau
mfrc522.PICC_HaltA();
bool surveillerPins() {
// Configuration des pins comme précédemment...
pinMode(13, INPUT_PULLUP);
pinMode(4, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP); // Ajouter le pin 8 comme entrée
pinMode(6, OUTPUT); // Supposons que c'est la LED rouge
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(6, LOW);
digitalWrite(2, LOW);
digitalWrite(3, LOW);
while (true) {
bool etat13 = digitalRead(13) == LOW;
bool etat4 = digitalRead(4) == LOW;
bool etat8 = digitalRead(8) == LOW; // Lire l'état du pin 8
if (!etat13 && !etat4 && !etat8) {
// Aucun pin n'est connecté à la masse, y compris le pin 8
digitalWrite(6, HIGH); // Allumer la LED rouge
digitalWrite(2, LOW); // S'assurer que la pin 2 est éteinte
digitalWrite(3, LOW); // S'assurer que la pin 3 est éteinte
} else if (etat13 && !etat4 && !etat8) {
// Seul le pin 13 est à la masse, le pin 8 n'est pas à la masse
digitalWrite(2, HIGH); // Allumer la pin 2
digitalWrite(6, LOW); // Éteindre la LED rouge
} else if (etat13 && etat4 && !etat8) {
// Les pins 13 et 4 sont à la masse, le pin 8 n'est pas à la masse
digitalWrite(3, HIGH); // Allumer la pin 3
digitalWrite(2, LOW); // Éteindre la pin 2
// La LED rouge reste éteinte
Serial.println("Sortie True");
return true;
} else if (!etat8 && etat4) {
// Le pin 8 n'est pas à la masse et le pin 4 est connecté
// La LED rouge doit rester allumée
digitalWrite(6, HIGH); // Garder la LED rouge allumée
// Les autres LEDs restent dans leur état actuel
// Dans tous les autres cas, revenir à l'état de base
digitalWrite(3, LOW); // Éteindre la pin 3
delay(10); // Petit délai pour éviter de surcharger le processeur
return false; // La fonction retournera false si elle sort de la boucle d'une autre manière (actuellement non applicable car la boucle est infinie)
void playLEDGame(bool buttonPressed) {
Serial.println("Début de playLEDGame");
FastLED.setBrightness(BRIGHTNESS);
if (buttonPressed) {
Serial.println("Bouton pressé");
Position = 0;
findRandom = true;
delay(40);
FastLED.show();
gameState = 1;
FastLED.show();
if (findRandom) {
findRandom = false;
// sleds[0].setRGB(0, 255, 0);
delay(300);
findRandom = false;
level = gameState;
gameState = 98;
gameState = 99;
// period = 320;
if (findRandom) {
findRandom = false;
// sleds[1].setRGB(255, 255, 0);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (findRandom) {
findRandom = false;
// sleds[2].setRGB(255, 50, 0);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (findRandom) {
findRandom = false;
// sleds[3].setRGB(255, 0, 0);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (findRandom) {
findRandom = false;
// sleds[4].setRGB(0, 50, 255);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
if (findRandom) {
findRandom = false;
// sleds[5].setRGB(0, 150, 255);
delay(300);
level = gameState;
gameState = 98;
gameState = 99;
winner();
loser();
FastLED.show();
Position++;
Position = 0;
void winner() {
tone(7, 1000, 250);
FastLED.show();
clearLEDS();
FastLED.show();
findRandom = true;
Position = 0;
gameState = 0;
void loser() {
tone(7, 200, 250);
FastLED.show();
clearLEDS();
FastLED.show();
gameState = 0;
void clearLEDS() {
void winAll(){
Thanks in advance for your suggestions and best regards
