I connected nRF24L01 to WEMOS D1. Here is the code I wrote
#include <SPI.h>
#include <RF24.h>
RF24 radio(2, 1); // CE pin = D9, CSN pin = D10
const byte address[6] = "00001"; // Pipe address
if (!radio.begin()) {
Serial.println("Radio hardware not responding!");
while (1);
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_LOW); // More stable on breadboards
radio.stopListening(); // Set as transmitter
const char text[] = "hello";
bool ok = radio.write(&text, sizeof(text));
Serial.println(ok ? "Sent: hello" : "Send failed");
Serial.println("ok");
The connectivity is as follows.
GND to GND VCC to 3V3
CE to D2
CS to D1
SCK D5
MOSI D7
MISO not connected
And yet when I start the sketch I get following errors
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x4010f000, len 3424, room 16
tail 0
chksum 0x2e
load 0x3fff20b8, len 40, room 8
tail 0
chksum 0x2b
csum 0x2b
v00042ca0
~ld
The pins are not labled but I have the module like this and I am following the attached pinout
Dziubym:
nRF24L01
Google found this : “An nRF24L01 pipe address is a unique, 5-byte address that defines a communication route between two nRF24L01 modules on a shared RF channel . While a transmitter uses one address to open a writing pipe, a receiver can have up to six reading pipes, each with a different address to simultaneously listen to multiple sources. The addresses for pipes 0 and 1 can be fully defined, but for pipes 2 through 5, only the last byte can be unique, as the first four bytes must match the address of pipe 1.”.
You define 6 bytes, but only fill 5 of them.
So haw does it affect my problem. Can you suggest what sould I change?
I don’t know, but change the array to 5 bytes and see. Are you using proper addresses for the pipe?
JCA34F
August 23, 2025, 8:07pm
5
Try replacing that line with:
radio.openWritingPipe(0xF0F0F0F0D2LL);
On both TX and RX sketches.
Why would this make a difference?
6v6gt
August 24, 2025, 8:44am
7
Dziubym:
MISO not connected
Do you mean IRQ not connected ?
Issue fixed. So two things:
MISO must be connected for both transmitter and receiver.
The command to declare the module should look like RF24 radio(D2, D1); and not RF24 radio(2, 1);
