I am trying to do a standalone atmega8 project using the 1MHz internal clock. I am using the Sketch->Export compiled binary option to generate hex files. Then I burn them(without the bootloader) to atmega8 using a USBasp.
Clearly I'm NOT worried about the boot loader. I use:
#define F_CPU 1000000L
in my sketch but the
command results in an approx 16 seconds delay. Which means the new frequency is not in effect(I was just blinking an led with 1 sec interval for testing).
I also tried putting
build.f_cpu=1000000L
in my preferences.txt. Still no change.
Any ideas?
However, since your sketch is compiled after the source files, the millis() function (which delay() is based on) have probably been compiled with F_CPU = 16M. You'll hit the same problem if you e.g try to redefine the Serial buffer size in your sketch. Let's say you increase it to 128. if you print the buffer size macro
Serial.print(SERIAL_RX_BUFFER_SIZE)
The serial monitor will print 128. Still the serial RX buffer is 64. Go figure!
Back to the topic; if you want to get this working properly without having to modify Arduino's core files, I've already done it for you! I've created a 3rd party hardware add-on for the IDE that adds extended support for ATmega8, ATmega48, ATmega88, ATmega168 and ATmega328. You can choose preferred clock frequency, BOD option and compiler LTO. You should definitely give it a try! --> GitHub - MCUdude/MiniCore: Arduino hardware package for ATmega8, ATmega48, ATmega88, ATmega168, ATmega328 and ATmega328PB
(If you'll ever want to dive deeper into the AVR family, you can find the rest of my work here)
You usually want to define F_CPU on the command line for the compile, rather than in the source.
How exactly this is done depends on the tools being used.
hansibull:
The order does not matter, it's the fact that they're compiled separately. Each source file is passed it's own F_CPU macro from the command line, which the IDE gets from the boards.txt file.
chitti:
Any ideas?
What is your clock frequency? The F_CPU define only tells the compiler what CPU speed to use for various delays and functions. It does not change the CPU clock.
For 1 Mhz clock, you need a 1 Mhz crystal, or a 16 Mhz crystal with [b]clock_prescale_set (clock_div_16); [/b]or the internal oscillator with [b]clock_prescale_set (clock_div_8);[/b] or the CKDIV8 fuse bit programmed.
