I'm the beginner to use dot matrix I use a simple code but don't display i want to know this problem
Link my work : https://wokwi.com/projects/357070643990808577
start with the hello world example as provided from the library:
adopt the pin setting and try it with real hardware.
Tell us what you see.
You should probably use another form of the constructor for MD_Parola which specifies also the clock, data and cs/load pins. See : Parola for Arduino: MD_Parola Class Reference
I think MD_Parola wants this: (I could not find pins 10 or 11 on your ESP)
MAX7219 | UNO |
VCC | 5V |
GND | GND |
DIN | 11 |
CS | 10 |
CLK | 13 |
I did get your MAX7219 working on a Nano (sim). It was not a pretty result on the simulator. If the Display.print()
is readable, all the letters are defined backwards.
Here is the link: bbxxm - Wokwi Arduino and ESP32 Simulator
