Had a problem with Audrino 1.0.2 so updated to 1.0.3 to see if it would fix a problem with a particular sketch as follows:
Open Examples / Blink compiles OK no problem here....
Open Examples / Time / TimeRTCSet but have a series of errors commencing as follows when I try to compile:
'time_t' does not name a type
In file included from TimeRTCSet.pde:11:
C:\AUDINO\arduino-1.0.3/libraties\DS1307RTC/DS1307RTC.h:17: error: 'time_t' does not name a type
C:\AUDINO\arduino-1.0.3/libraties\DS1307RTC/DS1307RTC.h:18: error: 'time_t' does not name a type
C:\AUDINO\arduino-1.0.3/libraties\DS1307RTC/DS1307RTC.h:19: error: 'tmElements_t' has not been declared
various other error lines follow on....
I've looked into DS1307RTC.h and can see where I thing time_t is referred (as below) so what is the problem. My copy of the library was downloaded from githum.com and included the CPP file.
I'm not too familiar with interreting these error codes so any hely would be appreciated.
- DS1307RTC.h - library for DS1307 RTC
- This library is intended to be uses with Arduino Time.h library functions
#ifndef DS1307RTC_h
#define DS1307RTC_h
#include <Time.h>
// library interface description
class DS1307RTC
// user-accessible "public" interface
public:
DS1307RTC();
static time_t get();
static void set(time_t t);
static void read(tmElements_t &tm);
static void write(tmElements_t &tm);
private:
static uint8_t dec2bcd(uint8_t num);
static uint8_t bcd2dec(uint8_t num);
extern DS1307RTC RTC;
#endif
