I am trying to connect ESP32 via bluetooth classic to my PC to transfer some data from a sensor.
As a first step, I am simply trying to send some random data over bluetooth serial. The code is at follows:
#include "BluetoothSerial.h"
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
int myData[8];
BluetoothSerial SerialBT;
Serial.println("Opening Serial Connection on COM4");
SerialBT.begin("ESP32"); //Bluetooth device name
SerialBT.println("Opening Serial Bluetooth Connection on COM6");
for(int i = 0; i < 8; i++)
myData[i] = random(0,500);
if(Serial.available())
SerialBT.write(myData[i]);
delay(20);
In Windows bluetooth settings, I have paired the ESP32 with windows and connected it. I have set up incoming and outgoing COM ports for bluetooth where incoming port is COM6 and outgoing port is COM5.
However, when I open arduino serial monitor for COM6, it is empty and no data is being printed. Furthermore, on COM4, there is nothing printed despite the Serial.println("Opening Serial Connection on COM4"); command which I think should work regardless of bluetooth.
I have tried everything I can think of. I would be grateful if anyone can help me solve this problem as I have been stuck for days
The posted code will only send data via bluetooth if incoming data is available from Serial, so you need to send data to the ESP from the serial monitor before bluetooth starts to transmit. The incoming serial data is never cleared, so whenever data is received bluetooth will be spammed.
You should try to modify your code to send data via bluetooth once every second instead:
uint8_t data = random(0,255); //Range!
SerialBT.write(data);
Okay, thank you for the help. It is working now with the change you suggested and also when SerialBT.write(data) is replaced by SerialBT.print(data). I am not sure why this is the case. Any idea why?
Thanks for the answer.
Yes, I understand that. However, for some reason nothing gets displayed on serial monitor when i use write(data). The values are only getting displayed when I use print(data)
Should print 2 times 'A'. Another thing to mind is that the serial monitor may require a line-ending (can be send with "Serial.println();") before the received data is displayed.
Okay, thank you for the reply.
One more thing, could you refer me to a serial library capable of fast communication?
Currently, I am using SimpleSerial and it is too slow for my requirement
